charlie1017
Exactly. I tell the Capt everything I do with the box.Usually goes about like this.
“Hey, I’m putting this speed in”
“Ok”
@BEEF SUPREME did you not just learn something in this thread? Lol
“Ok”
No, but on the VNAV page it has a current Vertical Bearing (V/B) , and vertical speed (V/s) to make the fix that the VNAV is looking at next.Does the 737 have a vertical direct feature?
I miss one thing about the Q over the 767, that is VTO (vertical direct to). Getting pulled off of profile vertically and laterally in the 76 is a pain during arrivals because once you’re again cleared via, you have no VTO or vertical direct to. The little diamond comes up after about 10-20 seconds of calculating, if you’re not close to the path there is a few more button pushes to get back on path. If it’s pegged you have to go to PROG PG 2 to see your vertical deviation. Same with a runway change, once you punch it in and execute your path disappears for a while, when it reappears again some intervention could be required if it is a busy arrival. Kind of a first world problem I know, but hey, keeps my 3/1 maths skillz sharp
I’m thinking it’s because the Boeing’s I fly were made in the 80’s and that wasn’t yet a feature of VNAV. Some of our -200’s don’t even have GPS lol.
“Ok”
Bonus, when does altitude intervention not work?
A Gulfstreamer and a JetU hero walk into a bar..
We’ve pretty much got the Yale Whiffenpoofs vs the Harvard Krocodiloes here.
*extremely jealous of the those in the industry.Only one walked out still in the industry and doesn’t hate the 737?![]()
The VNAV did not work in our 35As when they installed the dual Garmin 750s. We could VNAV it through the GPS, but it was not tied to the MCP.There’s a VNAV button in the Learjet, but I don’t think it works ever since they “upgraded” the FMS to Garmins.
I’m not impressed by our GTN Lear installation. I mean it’s a nice piece of hardware but in the Lear it feels like it’s kind of just a shiny toy rather than a serious FMS. Can’t even do LPV approaches with it which I’m pretty sure you should be able to do with the EFIS in the 31A.The VNAV did not work in our 35As when they installed the dual Garmin 750s. We could VNAV it through the GPS, but it was not tied to the MCP.
Boeing Logic: > 50 mi from TOD - recruise it. <50mi from TOD - Descent Now. If you get an immediate descent followed by a Descend Via: FLCH it then recruise it. If you get VNAV SPD in your descent, your ears should perk up.
I presume (I dont fly the 767) its because youre flying Cost Index. As such, upon re-cruise it will go straight to the calculated CI speed for the new cruise altitude.Recruise can also bite ya if you recruise more than once on the way down if directed to start stepping down early. The FMS speed will slow down and then you have to either speed intervene or re punch the desired FMS speed and transition. Happened to me a few times going into CVG, I didn’t notice but when center told me to speed up for traffic I noticed the FMS Mach speed was much lower than .79 or.80. Good lesson learned, so now I’ve backed the recruise vs des now to 80nm and only recruise one time. Anyone shed light on why the speed adjusts during recruise in the Mach levels?? I’m new to all this jet stuff lol
And regarding recruising distance, ive seen folks re cruising too close to the T/D for the old altitude, and then the green banana for the new altitude is *beyond* the new T/D. Hilarity ensues when pointing it out.. Followed by disbelief, then full speed brakes scrambling down.
