LoadMasterC141
Danke
Yeah...that was the part. The crew after crew coming down the escape rope, while untold more were still inside tossing bags of flight gear, luggage, and holiday gifts out the L-1 door. If I'm not mistaken, that video created an internal memo basically stating to "get out and not get personal items" in the event of an accident.
Not knowing how many are onboard, or even having a reasonable assumption, just makes our job difficult.
Here's the real story. I got it from the FedEx safety guy. And the assumption that the guys were just "saving their Xmas presents" is false.
The problem was there is only one evac slide installed. Its on the L1 door. As you can see from the video, the airplane is laying on its right side, elevating the L1 door. What you don't see is the wind blowing from the left. When the slide was originally deployed, it went under the aircraft. When it inflated, it either detached or was destroyed.
As a result, the crew only had one escape option...the cockpit windows. As anyone who has tried this escape venue, it takes some time. So, while the guys were waiting their turn to use the window ropes, they decided to start tossing out the crew bags.
They were not delaying getting out in favor of the crew luggage. They just didn't have access to the ropes and used the time to "evacuate" the luggage. What isn't apparent from the video is the crew/pax are coming out the window and the bags are coming out the L1 door.
CNN reports now FedEx has confirmed that a total of 4 flight crewmembers were killed. The names of the additional flight crewmembers has not be released. I'm guessing that either they were js'ing or relief crew.
atp
Won't happen, I wouldn't think at least. Depending on how the thing is designed, the ground spoilers could already be up and trying to get you to stay on the ground. Once those things are up, as far as I'm concerned, you're staying on the ground. If you push the thrust levers up they'll come back down, but as MikeD noted, the spool up time would mean they've got a while before the power comes back up.
No, go around is no problem until reverse is deployed.
You pop the reversers before there is a nosewheel on the ground to steer you if only one reverser deploys? Personally I was taught, and agree with the philosophy, that that way of operating is not good for one's career...When are the reversers popped on landing? I'd have mine out on the RJ just about as soon as I could get the thrust levers over the gate. Do you guys wait on the MD-11 until your nosewheel is on the ground?
Further, you can't spool the engines up until you have the nose wheel on the ground.
Indeed, every aircraft is different.
You've gotta consider that the differences between beta, full reverse, just having clam shell buckets opened, having full reverse with clam shell buckets, and whatever the other style of reverse open, vs. whatever the other style of reverser open plus thrust.
On an airplane like the CRJ, my understanding is that you have a lot more thrust moving forward than in a clam shell style setup. Now I haven't flown a CRJ, but that's my understand. I've been wrong before.
This is flat out false. There are two slides installed.
Yes, sorry to ask that in the present tense. Good to hear the logic from a former "big airplane driver":buck: My small airplane is definitely different. We have no WOW switch for the nose, so you could create some serious problems. You are not supposed to be able to spool engines up with only one fully deployed, but I have seen otherwise...it's usually a uncommanded stow, but you are still generating thrust on one. It could get ugly.Well, I pop nothing anymore, but yes. I dunno how much additional control you're REALLY going to have by having a VERY light nosewheel on the ground, but do what you need to do for your airframe to be safe.
The logic in the system would prevent you from doing anything too stupid. I'm obviously the anti current right now, but I believe you could still use one bucket/reverser if you had the other bucket MELed. Further, the airplane won't let you bring them out until you get weight on wheels (every once in a while you'd get a ding while bringing your nose wheel down because you had the thrust levers behind the gate, but the airplane was not convinced that the airplane was on the ground yet, so you'd get an EICAS message about it and the buckets would not deploy). Further, you can't spool the engines up until you have the nose wheel on the ground.
So like I said, do what you need to do for your aircraft. It's been 6 months since I've been in the cockpit of anything, but I seem to remember most guys flying the aircraft like this.
