Buzo
I have to get the FCTM out everytime I start an engine, it is so rare.
Done it in JFK. Don't even know who you are carrying but know what business you guys are in.If you knew who we were carrying, you'd give way.![]()
I seem to remember the 727 has a procedure for battery start, as long as at least the #3 engine bleed is open. (Otherwise I seem to remember you are hosed: the bleeds are either main or essential AC powered.)
"This one time, in Mexico..."You are correct. You can battery start the 727 with an air start cart but all the bleeds must have been open prior to shutdown as they are AC valves. That is why on the parking checklist it is confirmed that all 4 engine bleed valves are open. You also confirm the the quality of the start cart before you shut down number 3. I've been to a couple of places that claim to have a start cart only to find it hasn't been run in months and won't start.
It was messy enough on the jungle jet—I believe you!Don't get me started I did an entire rotation with NO APU and all mexico trips in summer. It sucked, big time. We had an 8 hour freight delay and wasted about 8000 lbs of fuel just keeping number three running. Then their is the whole refueling issue as you can't open the refuel valves when on an engine gen without using a PITA Special Procedure...
On a side note, it is always fun to have a jumpseater new to the 727 ride along. They usually can't believe the fuel flow on take off is 30,000 to 36000 pph
We normally prioritize APU starts, unless there is a reason to crossbleed. You have to run the operating motor up to ~ 80% power to do it (my aircraft specifically), and this isn't always a good or helpful thing to do with other aircraft around/behind you. That and you already have the APU running to start the first motor generally, so it's no easier unless you have been troubleshooting or something that required you to shut down a previously running motor and now you want a quick re-start.
Some jets still retain the capability. It was mainly bombers/tankers that used them, but some fighters could too back in the day.
But you guys have a different kind of fuel budget. Airlines are trying to reduce the amount used.
Whereas, with the military, "if you don't burn the fuel budget, you lose it."But you guys have a different kind of fuel budget. Airlines are trying to reduce the amount used.
The use it or lose it mentality is what is wrong with the gov't. If you were responsible you should be able to " bank it" for future use or "trade it" for other items you may need...
I don't think the "use it or lose it mentality" truly exists and is just something line pilots/soldiers/sailors, etc say as common knowledge and is passed around from person to person without the involvement of a budget/fuel/flight hours manager.
I don't know how it is with the Army side, but this is definitely a front office concern in every squadron I know of. It isn't "use it or lose it", but the mandate is "you will use your hours". And this becomes Ops concern, and thus everyone's concern. Generally speaking, we are able to get training out of the unusual amount of hours we sometimes have to fly. The ones it really burns are the guys and gals downstairs trying to keep the jets up. Especially the night shift folks who have to fix everything after we land late at night. It also is noticeable on flights like my fri afternoon hop, where we basically had to knock it off after 2 BFM sets and just hold at 230 kts for 30 mins to both log a 1.0 as scheduled.
I can tell you it absolutely used to be true up until about 5 years ago. If you've ever worked in Wing Programming in the OG or the OSS, you'd know it is a legitimate threat. Remember, line pilots have zero to do with flying hour programs; SQ/CCs and DOs are simply doing the bidding of the OGs and Wing/CCs. It is those Wing Kings and OGs that are involved in the yearly negotiations of those flying hours.
Now, it's interesting -- wings are "selling back" unused programmed flight hours, and the HQs are loving it because of the fuel budget savings. Guess what...subsequent years flight hours ARE being reduced following those turn-ins, but the operational units just don't have the people or iron to be able to have used those 'lost' hours anyhow. Pretty sad state of affairs.
Guess you didn't see my next post (#75)?
No, I didn't. None the less, your situation is a little different.
I can tell you, though, that it definitely used to be true for active duty USAF.
