Chief Captain
Thanks. Quite an interesting read. I hope the new philosophy doesn't cause trouble.
Depends on the operator. At Southernjets, cross bleeds are normal procedure. It's all part of the fuel mitigation plan. They track APU use time closely. Gotta watch out for the APU sheriff. ( An actual management position!)So when would this procedure be used? When the APU is inop for some reason?
Edit: Thanks for reading my mind, Alchemy.
At Eagle, we were supposed to shut the APU down right after the first engine start and do a cross-bleed start for the second engine. Supposedly, anyway. It turns out that one engine at idle thrust doesn't give enough bleed air extraction margin to run the packs in the summertime in Dallas. SOP was to do a crossbleed start on the straightaway (you have to stand the operating engine up to 80% N2, which is a good bit off idle) but given climactic conditions in the summer this procedure is very rarely accomplished.So when would this procedure be used? When the APU is inop for some reason?
I've heard of this person, they have a badge and everything right?Depends on the operator. At Southernjets, cross bleeds are normal procedure. It's all part of the fuel mitigation plan. They track APU use time closely. Gotta watch out for the APU sheriff. ( An actual management position!)
I believe the CRJ has both an electric starter and a bleed air starter.
Cross bleed start;
To get the first engine started you use something like this:
Have the ground crew hook it up, turn the air when you're ready to start, engine spins, introduce fuel and PFM from there.
Cross bleed start; thats childs play. Now.....cartridge start, that's something to see. Here in video at 0:11 and 1:52. Used extensively by the B-57, B-47, B-52 and KC-135 aircraft (except R model, I believe).
One of my CRJ-flying coworkers was bemoaning this fact yesterday, as his APU was INOP. Which is a bummer in that airplane (and the ERJ) because many stations either don't have start carts, they don't work, or they are slow to hook them up and remember the procedures...All pneumatic. No electric starts except for APU.
Have you done a buddy start?
What exactly is a cartridge start? Is that the same as a bottle start?
MikeD, that was freaking sweet. I though cartridge starts were a thing of the past for radial engines.
I don't know; I fly the Brasilia, where both the engines and props must come to a stop before anything can approach the aircraft other than the guy with the chocks.If he was really that concerned about the quality of the air start carts, couldn't he have simply left the #2 running? Are you allowed to refuel with the engine running?
Doesn't the F-18 use a hydraulic accumulator to start the APU?
Yes - that was the RJ-appropriate explanation I was looking for.We can but it's a big pain. You shut down the left engine so the people and bags can unload. Then you crossbleed start the left and shut down the right so the fueler can do his thing (can't hot refuel with pax on board). Once he's done you crossbleed start the right and shut down the left so the people and bags can be loaded and then finally you shut the door and crossbleed start the left.
