TFaudree_ERAU
Mashin' dem buttons
We did run lean of peak if I remember correctly.
I always got the impression they were the stock EGT's
Please oh please say it ain't so
My mistake, Amflight opeates rich of peak, but also has a limit on the EGT that they're not allowed to go past when leaning.
But even if you were to run that same engine lean of peak, if you're got an EGT guage and a CHT gauge you shouldn't have any problems doing so as long as you're paying attention to what you're doing. You won't have the advantages of having a probe on each cylinder, but if you have other limits you shouldn't exceed (both EGT and CHT) along with listening to how the engine is running, it shouldn't be a problem.
At 8,000' if you pulled the mixture back too far you'd choke the engine real fast, which should be your first indication that you've screwed something up.
The gauges though, this is confusing to me about why you can't run LOP without having probes on all your cylinders.
If you're running 25 degree's lean of peak, what does the FF matter apart from the injector being of a high quality? I.E. If shouldn't the accuracy of the gauge matter more than whether it's digital or analog? Also, if you've got your probe on your hottest cylinder, doesn't that protect the rest of the engine? I.E. You set 25 degrees LOP and then if the engine happens to get too hot, you're watching the CHT's and you add a little bit of gas to the mix to cool the engine off eh? Or said another way, if you've really botched it and you're running AT peak, you're going to have more than one sign of doing so eh? Or at least that's what I would think.
Does that all make sense?
You are correct for the non-turbo. But leaning procedures are a whole different story in the turbo, you do not use the lean assist. It is all done based on initial setting of fuel flow to 17 GPH, then adjustments based on CHT's. EGT's are not used for leaning but they are monitored to make sure they dont get out of limits.
How do you know that the EGT gauge is on the hottest cylinder? You don't. Actually, a single probe EGT is located in the exhaust manifold, not at the exhaust port as it is in a multi-probe installation.
Analog gauges just aren't as precise as a digital gauge. Can you measure 1436*F on your analog gauge? I can on my digital.
You have to know precisely which cylinder is the hottest to run LOP. Thats the key. You would assume the rear cylinders, but you'd be surprised. I've found that sometimes the middle set of cylinders on the Cirrus are the hottest.
Really? See I've asked mechanics about that, "How in the world do you know which one is the hottest."
They've said, without fail, it's the cylinder that receives the least amount of airflow over it. I think in the Chieftain that was the number six cylinder, so they ran the probe off of that one.
How often have you found that the hottest is in the middle? I know it can change depending on a lot of things, but have you found a predominate answer on that?
1 and 2 (at the back) are always hotter than 5 and 6 in ours, usually by around 40 degrees.Really? See I've asked mechanics about that, "How in the world do you know which one is the hottest."
Im a CSIP Instructor with over 500 hours in the 22 Turbo. I dont like leaning using your method but alot of Cirrus Pilots do it as you described. Cirrus NOW recommends leaning to 50 degrees LOP, In fact on their Perspective planes all you do is pull the mixture lever back to the arrows match up which will give you 50 LOP.
How long ago did you go through the training miller?
Also I could of sworn that the CHT's were 425 red line 400 max in cruise and about 380 normal in the turbo. I may be confusing numbers with the 20.
