Hold on, my head's spinning here and I don't think you're getting the nuances of how to lean an engine correctly.
There will be two peak points when you lean an engine. First you'll set to your GPH (a ballpark figure) and proceed to lean from there. Now if I remember correctly, once you hit that first peak number, you should go and enrichen the mixture a little bit and when you lean it again you'll end up with your real peak number.
At this point, check your CHT's and make sure you're not above whatever number you're using for your max CHT.
Further, I believe 380 is the max number you should ever run your engine at on a regular basis if I read Tornado Alley's website correctly.
To be honest, you probably haven't been trained properly on how to lean correctly, nor do you have much experience with big engines just yet to understand how to care for them properly. We went through a 6-8 week training program to qualify on the Chieftain for initial, and you were probably tossed into the Cirrus with a few hours of dual.
