Richman
JC’s Resident Curmudgeon
I have no problem with user fees…
…for aircraft over 12,500lbs MTOW or that are turbine-powered.
Even if it’s like that at the start, no way it stays around, and ADS-B is the perfect billing method.
One ought to get something tangible for the money they spend. There’s a fine line between free market and fleecing. At the end of the day, they charge what they charge, because carriers pay it. Simple as that. How they do it on a ramp that is owned by the government, im not sure.
I flew with a guy who was a Greyhound driver and we spent a good amount of time laughing at that.truth. Which grounding……er, operational pause….are we on with the V-22 Osprey now?
ok I was against it before but this single issue would change my mind"Thank you for using guard. Our fee is $5 per cat noise. Calling it Delta radio is $20. Pretending you're an FBO or airline ops is $100"
I’d like you to elaborate on this as well. The elements of it I’m familiar with, as well as what I’ve skimmed from wiki, seem like they work fine and were a needed upgrade. Once again the biggest issues seem to be grift by for-profit contractors, and reluctance by NAS users to upgrade and participate.
Do you think we would have this under NASA without contracting with the private sector?Maybe, but at the time they were privatized they still served a useful function and Lockheed took them from doing that well to being absolutely • useless in a matter of months.
I dunno, working for an airline it sure seems like we (and all our competitors) have those three problems in abundance. I’m eternally skeptical of privatization fixing any of them.
I’m not sure I’m following your suggestion. This feels like a natural continuation of the original - unless I missed something in my skimming(?).@SteveC
Given that this thread is now a necropost starting from Post 51, should we maybe make a new thread from there if we're discussing things?
Especially given the incoming administration, do you see any remotely realistic chance that the above doesn’t happen during a privatization scheme?Again, the problems at air traffic are because it’s already run too much like a business. Too many idiot VPs of so and so, and refusing to listen to the rank and file re: amount of work vs. manpower available. Just like every single aviation business I’ve worked for. What really needs to happen is the FAA and DOT need to put their foot down on traffic at certain facilities and limit slots etc to something more appropriate to the staffing. That’ll never happen, because again, they’re operating like a business where pushing the tin, not safety, is priority.If a company like Boeing were put in charge of the privatization of ATC, we're all hosed.
Boy howdy.Just like every single aviation business I’ve worked for.
I’m not sure of the particulars here, but I’d bet a fast food burger of your choice that the cost overruns are because of •bag for profit corporations who submit unrealistically low bids with generous change order clauses. Then, because of shortsighted efficiency and budgetary policies, managers are forced to take the low bid and pay out the nose when to no one’s surprise, the bid was unrealistic. BTW this is based on real world experience with an FAA Next Gen project in which everyone on the front lines knew the winning bidder was never going to be able to deliver, but they submitted a better and shinier bid than Garmin, and then ran very late, upcharged, and delivered a substandard product that required multiple hacks to make it work.The budget was blown up, it has failed to remain on target for milestones, and it will have less of an impact than was originally stated. The FAA is also fudging numbers to game certain milestones.
The DOT published this report earlier this year: https://www.oig.dot.gov/sites/default/files/library-items/FAA NextGen Status Report_4.30.24.pdf
View: https://www.youtube.com/watch?v=RYUr-5PYA7s&themeRefresh=1
It's clear something is very wrong with the current system. If that could be fixed, fix it.
There is an eight year gap in the thread. The people having the conversation right now would very likely not be having the same kind of conversation that they would have been having eight years ago. Link the threads if you need to, but I think separation is in order for anyone coming to this from the outside.I’m not sure I’m following your suggestion. This feels like a natural continuation of the original - unless I missed something in my skimming(?).
I still think we should institute public canings for pilots who meow on guard or otherwise misuse emergency frequencies.
Penalties for taking another aircraft’s clearance, handoff or transponder code will be $37.
“Center, was that for us?”
