Having never been to a crash scene, is this something that could be caused by debris from the crash (rocks etc kicked up) or most likely what it appears to be?
View: https://x.com/clashreport/status/1871901418820624792?ref_src=twsrc%5Etfw%7Ctwcamp%5Etweetembed%7Ctwterm%5E1871901418820624792%7Ctwgr%5E%7Ctwcon%5Es1_&ref_url=
That looks like how I bring back the plane every time I play DCS. Extremely suspicious.Certainly looks like a frag pattern to me.
If so, it's morbidly impressive how many modern commercial airliners have been lost due to the Russia\Ukraine conflict (I count the Donbass region civil war in that as well) vs all the other conflicts in modern history where aircraft being flown by reputable carriers (AZAL has been around a long time and was the first airline in the Aeroflot break up to build up a Western fleet with 757s and 737s and have unrestricted growth in Europe) aren't being blown out of the sky...I think this thing was probably shot down…
Wow, I had no idea. All the more reason to give that area a wide berth.It’s the first long conflict since maybe the 1980’s where both sides have active air units that is also located where people actually want to fly to
I can’t wait for the Russia cucks to be like “this is why we can’t send Ukraine any more weapons!!!!”If so, it's morbidly impressive how many modern commercial airliners have been lost due to the Russia\Ukraine conflict (I count the Donbass region civil war in that as well) vs all the other conflicts in modern history where aircraft being flown by reputable carriers (AZAL has been around a long time and was the first airline in the Aeroflot break up to build up a Western fleet with 757s and 737s and have unrestricted growth in Europe) aren't being blown out of the sky...
One detail I find interesting is that the Russian commercial airport nearest to the location that the emergency started was closed for military activity at the time. I mean, why aren't the airways?
It's a discussion we have when crossing the North Pacific. We're only a few miles from Russia airspace at that point.Years ago, we had a 76 do a precautionary engine shutdown and Russia was the nearest suitable. Captain decided to continue to Japan for 3 hours. He got a lot of criticism for that (myself included). Maybe it was a smart move.
Video allegedly from the cabin of the flight while still in air. There's very obvious damage to the bulkhead and oxygen overhead panel caused by something.
Which in it self isn’t a big deal. We have seen countless o2 panels damaged by inflight upsets and people hitting the roof.
But if you slow down frame by frame to when he zoomed in you can see shrapnel holes in the plastic. And that ain’t from someone’s head hitting it.
Yes.Is the 190 fly by wire?
Isn’t one of the axes normal cable+hydraulics?Yes.
Ailerons are cable linkage to a hydraulic PCU. Spoilers are FBW, and back up the ailerons, so it's not a fully manual axis.Isn’t one of the axes normal cable+hydraulics?
Can’t wait for them to be held to exactly zero accountabilityAilerons are cable linkage to a hydraulic PCU. Spoilers are FBW, and back up the ailerons, so it's not a fully manual axis.
Elevators and rudder are fully FBW.
You'd need to lose hydraulic pressure from all three systems to lose elevator authority, or fully lose electrical power. (There's a 15 minute backup battery for the flight controls should all other electrical systems be lost) Even if you lost all hydraulic pressure to the elevators, the trim would still work.
These airplanes are tough and robust, and not prone to getting holes like that under normal operating conditions. The engines aren't at an angle that would make uncontained failure produce holes like that, nor is it easy to imagine they came from an explosion inside the fuselage or baggage compartment, absent something real weird going on.
If what it looks like happened actually happened, then f—.
