I scrolled through the PDF but was anyone able to pick up on anything saying about getting the ATP written done before August, that you wont have to go through the ATP CTP??
Here is what I found regarding the written. It seems to me that if you get it done before the rule change takes effect you will not have to go through the course.
5. FAA knowledge test for an ATP certificate
In the NPRM, the FAA proposed to revise the aeronautical knowledge areas in §61.155
to incorporate the new knowledge areas in the ATP CTP. We noted that such a revision would
result in changes to the ATP knowledge test. Commenters such as IATA and the IFL Group
believed the current ATP knowledge test is inadequate. Commenters assert the current
preparatory products available to applicants of the knowledge test only ensure rapid rote
memorization of the material and not knowledge retention. The FAA concurs and has determined
academic knowledge gained and evaluated in a classroom setting, reinforced with demonstration
and experience in an FSTD, and then validated by a revised written knowledge test gives the
applicant the best chance of knowledge retention. This knowledge will allow the student to
perform more effectively upon entering an air carrier environment—the ultimate goal of the Act.
The FAA also proposed to extend the validity period for the knowledge test for an ATP
certificate to five years in consideration of the applicant’s time and financial commitment to the
ATP CTP. The FAA considered the extension appropriate due to the proposed elimination of the
ability for air carrier pilots to use expired knowledge tests. The FAA received no comments on
this proposal. In the final rule, FAA has retained the five-year validity period forthe ATP
knowledge test only for those pilots who pass the knowledge test after having completed the
ATP CTP – meaning any test passed after July 31, 2014. The FAA has also retained the
provision that allows pilots employed by certificate holders in parts 121, 125, or 135 to use
expired knowledge tests. As set forth in §61.39, pilots employed in parts 125 and 135 may use an
expired knowledge test if they have completed the ATP CTP and the operator’s approved pilot-66
in-command training or checking program. New hire pilots in part 121 operations may use an
expired knowledge test if they have completed the ATP CTP and the operator’s initial training
program.15 These pilots employed by air carriers are subject to additional training and evaluation
requirements that will ensure that they have a continued understanding of the general concepts of
the ATP CTP. If an applicant outside of an air carrier environment fails to take the practical test
within five years of taking the knowledge test, he or she must retake the knowledge test to
validate retention of the subject areas of the ATP CTP. The FAA has modified §61.35 to make
clear that a person may not take the knowledge test for the ATP certificate with an airplane
category multiengine class rating until the person is 18 years of age.
Finally, as set forth in existing §61.49, those applicants who fail the knowledge test for
the ATP certificate after completing the ATP CTP are required to receive the necessary remedial
training from an approved ATP CTP training provider and receive an endorsement before
retaking the knowledge test
