Any Airbus pilots out there? Help me please.
Here's a couple of questions I have not been able to find the answer to some time, thanks any help.
So here are some questions I'm really trying to find, but havn't yet,
1. When on approach, do you always fly with seletected speed on to maintain the calculated Vapp speed as determined in the APPR phase on the FMGC, or can you physically move the throttles from indent to indent to gain, bleed of speed?
2. On a typical take-off, and approach in the evening, or early morning, can you have the panel lights on? You know the orangish colored lights that are just under the FCU?
3. On departure, when you advance the throttles to FLEX, or TO/GA, after you pass the CL indent, does it automatically turn on the A/THR then as you move it to the FLEX or TO/GA take your hand off the throttles? For example, when taxing, say you need to give the jet some thrust, can you go past the CL indent without the A/THR turning on?
4. When the altitude call-outs are made on flare, do you yourself always retard the throttles when that call is made? Or say your a little high will you retard before, and the same thing when too low, and just retard after the call-out was made?
5. I know Flaps 2 is not permitted on the A320, so normally what flap setting do you use to depart? What about the 319, and 321, would it be Flaps 2? Why would you use Flaps 3, and Flaps 1 for departure?
Thanks,
Thanks,
