jawright
thats the one we used at flight school
L
C
W
B
F
A
T
C
O
W
S
We use that same one...at least that's the one I was taught. "LC Will Buy Fat Cows."
L
C
W
B
F
A
T
C
O
W
S
LCWB is a very popular acronym for an Air Force Academy graduating class.
So what else is the answer besides the added weight contributing to the HCL? Is it just more force being applied to the point of rotation?
Class of '79, IIRC.LCWB is a very popular acronym for an Air Force Academy graduating class.
Actually, "Most Unfavorable Weight" would be a lighter aircraft. Vmc decreases as weight increases.
Poster said:Care to explain that? As I understand it, more weight = higher angle of attack = higher P-Factor = higher Vmc
Most unfavorable weight- I think by this they're assuming you understand with increased weight you will get a decrease in performance. Therefore unfavorable weight would obviously be MGW.
The larger the HCL, the more of a sideslip to the good engine you have and the greater the directional control.
It's more of a paper reduction that a real one. In reality, you're going to be shooting for zero sideslip and won't be able to take advantage of the greater weight; it will only reduce your climb rate.
The regs don't specify the condition, so I'd expect that the manufacturer is going to take every opportunity to maximize their performance figures, which would be at ZS. That said, a test pilot will only be able to maintain zero sideslip if he can determine it. The only real way to do that (that I know of) is with a yaw string; in lieu of that, they maybe be using 5 degrees as an approximation to ZS. One test pilot I discussed this with seemed to equate ZS with 5 degrees, but when I pointed out that you'd be slipping the other way, he agreed that this was probably the case. I highlight probably because it indicated that he didn't know, which suggested they weren't making a serious effort to determine the ZS bank angle. This is likely to vary among test pilots and manufacturer, so I'm inclined to say "No way to know."Now, Are the performance numbers in the PA44 or any A/C for that matter, published based on ZSS bank angle or the maximum 5º the FAA allows? Because that would make a difference in climbing performance!
If I understand what you're saying, you're arguing that the higher HCL is needed in order to accelerate a heavier airplane sideways. Although a higher force is needed to accelerate a heavier airplane sideways at the same rate, the rate at which we accelerate isn't important. All that affects is how long it takes to establish a steady sideslip, not whether one will occur or not, nor its magnitude. The Vmc maneuver is from an equlibrium condition, where the sideslip has already been established, regardless of how long it took. With a particular bank angle, the aircraft will accelerate sideways until the drag is equal to the lift force.I think what I'm trying to say is.. whether it's light or heavy, whatever force it takes to get the airplane to turn at certain rate. again.
Seems unlikely to be significant, particuarly since the direction in which it would change Vmc is opposite what we know to occur.What about the Higher AOA higher P-Factor theory?? is the yawing moment really that great to cause a big change in VMC?
We don't know that those things make Vmc higher in any particular airplane. Some of the criteria for the Vmc measurement are just for consistency of testing among all airplane. However, flaps have been shown to increase directional stability in some airplanes (which would reduce Vmc). This is why many manufacturers suggest using partial flaps when landing in a crosswind.Is that what makes Flaps UP (or T/O position) and out of Gound Efect factors give us higher VMC?
he Seminole in an engine out has the best performance at 2.7 degrees of bank to be exact, I
[FONT=Courier New] Cessna[/FONT][FONT=Courier New] Piper Beech
[/FONT][FONT=Courier New]Crusader Seminole Baron 58
[/FONT][FONT=Courier New]ZS Bank: 1.5 2.1 2.7
[/FONT][FONT=Courier New]Ball Defl: .3 .4 .7
[/FONT][FONT=Courier New]ROC Change[/FONT][FONT=Courier New] (0 to ZS) +42 +62 +105
[/FONT][FONT=Courier New]ROC Change[/FONT][FONT=Courier New] (ZS to 5) -91 -92 -76
[/FONT]
Melville Byington, a professor at Embry Riddle, did flight tests on a number of aircraft, including the Seminole. His figures:
His figures show that the ROC penalty for every degree over ZS is 26-33 fpm.Code:[FONT=Courier New] Cessna[/FONT][FONT=Courier New] Piper Beech[/FONT] [FONT=Courier New]Crusader Seminole Baron 58[/FONT] [FONT=Courier New]ZS Bank: 1.5 2.1 2.7[/FONT] [FONT=Courier New]Ball Defl: .3 .4 .7[/FONT] [FONT=Courier New]ROC Change[/FONT][FONT=Courier New] (0 to ZS) +42 +62 +105[/FONT] [FONT=Courier New]ROC Change[/FONT][FONT=Courier New] (ZS to 5) -91 -92 -76[/FONT]
In all, better to be light, rather than heavy, no matter what it does to Vmc.
Are you saying that VMC wouldn't change between the light and heavy aircraft if both are banking for ZSS only?
Critical Engine:
I'm not sure if this is correct but I heard that "Spiraling Slipstream" effect on directional control does not really exist! unless the airplane is in a slip!
I probably woudn't recommend someone walking into a checkride with this degree of agnosticism, but I'd also rather not see them drawing a curving slipstream!
