That's a lot of pre made sandwiches on the table, who get's to eat what's on the grill? And why isn't that thing on a trailer?
Fortunately in that setup the 120VAC was a standard 3-prong household plug.Ohh yah, hadn't thought of that. Probably shouldn't confuse the two unless you want more airplanes to end up looking like that poor Airbus.
I was once privy to finding an orange extension cord on a Lear buried under the carpet, hooked on one end with environmental splices to an inverter and the receptacle on the other end actually had been epoxied and zip tied into position. Never trust a private jet from south Florida.Fortunately in that setup the 120VAC was a standard 3-prong household plug.
Just curious, do ANY of these rampers know how to use a flightline fire extinguisher? They are located on the ramp under nearly every jetway, ranging from 150lb units to 300lb units. These kinds of situations are the exact reason they are located there. Why have them at all, if personnel are either not trained how to use them, or simply don’t use them, but instead run around in a disorganized manner and accomplishing nothing?
View: https://youtube.com/watch?v=h9r17ccUn8U
Paging @Cherokee_Cruiser. Paging @Cherokee_CruiserDoes Delta have some sort of Emergency Deplaning procedure? This would be like, "leave everything, and exit out the jetbridge"
Ah so that’s what they do with all the birds they hit
I also have to speak about an airplane that had to get everyone off shortly after they started the engines and things went sideways. Airplane was sitting on the ramp for an hour with the APU running waiting for pax, they finally show up, load up and the safety briefing is done. Everyone is in their seats and after the right engine is started acrid smoke begins to creep into the cabin. No one was hurt and everyone got off the airplane without any other issues. Gulfstream, in the constant search for weight savings, used 8 AWG solid aluminum wires between each engines transformer/rectifiers and the power distribution box. There was an obvious hiccup in the PDB that day, and it cooked the insulation on that single wire run, yep, those big aluminum wires were one piece, no connectors or terminals between the tail to just behind the cockpit. During the repair the thought of just scrapping the airplane started to make sense. But it got fixed and it's still flying.Paging @Cherokee_Cruiser. Paging @Cherokee_Cruiser
I can tell you there is a rapid deplaning via jetbridge procedure here.Does Delta have some sort of Emergency Deplaning procedure? This would be like, "leave everything, and exit out the jetbridge"
The L1011 could make the field go IFR on a cold start!Usually black smoke isn’t good. The 75 P&W belches out a ton of white smoke when it’s cold out. So much that if I’m glancing back that way I can see it.
I recall we once had a G-IV that started to blow 20' fireballs out of one of the tailpipes on start up, other than the combustion display the engine ran perfectly, it was pretty impressive. The old Tays did not have any sort of FADEC at all. Upon inspection it was found that over time enough wear and stretch had been introduced into the cables and linkages that controlled the mechanical fuel control that the fuel cock wasn't quite reaching cut off. It would shut down normally because of the amount of air going through the engine, but on start up with the addition of just the right amount of undesired fuel with a relatively small amount of air and then the introduction of the igniters popping off it got rowdy. We re-rigged the engine controls, verified, re-verified and tested it multiple times with no fire balls and sent it on its way.
To be fair, I did NOT start this thread. This post was buried inside another thread. It was broken off and started as a separate thread by a mod. I wouldn’t have started a separate thread for this.
They aren't supposed to attempt to fight something like this unless they have extra training from another walk of life. I'd have pulled everyone the hell away and called airport fire immediately. Even the managers have the same very very rudimentary training, only meant for like trash or paper fires not an actively flaming GPU plugged into an aircraft. The average ramper of ramp sup/Manager alike would have no idea what to do here other than call for help.i
Exactly 0 training I saw at UA, DL, WN ect about aircraft related fires beyond GTFO.
I'm sorry. I do have a knack for pointing out the obvious and annoying people. Thank you for not resorting to personal attacks that many seem to on the interwebz.
So who uses the flightline fire extinguishers that are next to every jet parking area, under every jet bridge, and why are they even there? As ramp decorations? What’s the point of having them?
All the MD-11s would do the same in Anchorage on a cold morning.The L1011 could make the field go IFR on a cold start!
