Easiest acronym I know of:
C Critical Engine Inop and Windmilling
O Operating Engine-takeoff power
M Maximum Gross Weight
B Bank 5 degrees into good engine
A Aft CG
T Takeoff configuration, gear up
S Standard Day at sea level
<<heavier aircraft is more stable and has more inertia; >>
You hear this a lot and it's wrong on several fronts:
1) Inertia will potentially only affect the *rate* at which control is lost, but will not determine *whether* it's lost.
2) Even so, an aircraft rotates around the CG, therefore the weight alone will not affect the nature of rotation around this point.
That's what I always thought as well. I subscribe to the heavier a/c having a higher Vmc (because of AOA/P-factor) camp...
I'm not sure why people believe Vmc for every aircraft was tested at max gross weight but perhaps you've read something I haven't. Piper tested Vmc for the Seminole at a weight of ~2730, which is the most unfavorable weight with regards to directional control. Read below:
§23.149 Minimum control speed.
(a) VMC is the calibrated airspeed at which, when the critical engine is suddenly made inoperative, it is possible to maintain control of the airplane with that engine still inoperative, and thereafter maintain straight flight at the same speed with an angle of bank of not more than 5 degrees. The method used to simulate critical engine failure must represent the most critical mode of powerplant failure expected in service with respect to controllability.
(b) VMC for takeoff must not exceed 1.2 VS1, where VS1 is determined at the maximum takeoff weight. VMC must be determined with the most unfavorable weight and center of gravity position and with the airplane airborne and the ground effect negligible, for the takeoff configuration(s) with—
(1) Maximum available takeoff power initially on each engine;
(2) The airplane trimmed for takeoff;
(3) Flaps in the takeoff position(s);
(4) Landing gear retracted; and
(5) All propeller controls in the recommended takeoff position throughout.
I know this thread is old, but actually FAR 23.149 did not say that "VMC must be determined with the most unfavorable weight" back when Piper Seminole was certified, All V speeds are based on gross weight unless otherwise specified in the POH, and the POH for the Seminole doesnt say which weight VMC was calculated on.
The FAA has revised FAR 23.149 saying that it must be based on the most unfavorable weight AFTER Piper determined VMC speed for the Seminole, so its based off of max weight of 2800 I believe.
Not quite true. The way it used to read was"The maximum sea level takeoff weight or any lesser weight necessary to show VMC"Part 25 still reads this way. The thing is, most often it was necessary to use a lighter weight in order to show a Vmc, because at max gross, the aircraft will usually stall first.
Regardless of the regulation, the normal practice for flight testing is and was to use the lightest weight. I have little faith that anything in the POH is accurate in regards to how the test was actually performed. The writers probably just copied the regulation.
Fly_Unity said:Interesting, I read through the whole 23.149 CAR 3 (early 23.149), I could not find where it said lesser weight necessary to show VMC. Even the airplane flying handbook says that it didnt regulate what weight it was to be tested at (12-28)
VMCmust be determined with the most unfavorable weight and center of gravity position and with the airplane airborne and the ground effect negligible,
I have looked for my old copy of 23.149 (pre 1980) I had and couldnt find it, nevertheless Airplane flying handbook says that the the early FAR 23, AND CAR 3 didnt specify weight for VMC, and that all V-speeds are based on gross weights unless otherwise specified in the POH.
Who knows though what piper actually did though.
So your saying that they just did it because it was a common practice?
I agree that they tested it lighter, not because of performance, but because it will NOT VMC at gross weight at their altitude. The question isnt what they tested it at, but what weight, was the caculated 55 knot VMC speed based on.
that is straight out of 23.149, Vmc is to be determined at the most unfavorable weight for Vmc, not for performance. in this case Vmc must be determined at lightest weight
doh, i read the whole thing too, i was just not fully awake yet.Fly_Unity is arguing that aircraft certified before 23.149 was written that way might have been tested a max gross weight.
anyway, for sure the seminole was tested under 23.149 becauase it was certified March 10, 1978 according to the data sheet for it
i was looking at the data sheet for the PA-30 and PA-39 twin commanche's and the PA-30 has a higher Vmc speed (it was under CAR 3 regulations) BUT it also has a critical engine, whereas the PA-39 looks like it has counter-rotating props. The PA-39 was certified under Part 23(i think, but i might have misread)That was my guess. However, 23.149 did change in 1996. And at one time, it was merely copied from the former CAR 3 regulations, so the regulation has evolved. Tough to say how it read in 1978.
