JeppUpdater
Some solid work here...brrrrrrrt gun malfunctions (self destructs?) blowing the canopy off and damaging the gear. Well done, a breezy flight and and a tank of an airplane!
Capt. Brett DeVries was part of a four-ship on a routine training sortie from Selfridge to the Grayling Air Gunnery Range. After performing six bomb passes over the gunnery range to drop their ordinance, each A-10 took a turn firing the 30mm gun. However, on his second pass, at 150 feet AGL (Above Ground Level), DeVries’ gun malfunctioned. Simultaneously, the canopy of his aircraft blew off. After climbing to a safe altitude and outside the range patterns, in bound to the closest airfield, DeVries, chased by his wingman, tried to lower his landing gear: the gear started to come down, but the nose gear was hung up from the gun damage leaving no other option than retracting the gear and perform a belly landing.
When retracted, the Thunderbolt II’s main landing gear wheels remain partly exposed: during a belly landing, depending on the stores carried by the aircraft, the wheels that partially protrude from their nacelles can provide a cushion to absorb the impact with the runway; they can also reduce the risk of fire and generally speaking, the overall damage to the fuselage. In addition, when the gear is up, the wheels continue to guarantee the braking action, allowing the pilot to control the aircraft through differential use of the wheel brakes.
