I apologize for not answering your e-mail earlier; we are currently experiencing an overwhelming number of e-mails and phone calls.
This is a lengthy process and could take a year, as a minimum, or longer from the day you apply to the day you would be able to start the academy.
We will evaluate your application to determine if your work experience/college meets the minimum qualification. If you meet the qualifications, you will receive an email from our contractor, RVA, setting a date/time/location to take the ATSAT test. This process could take up to 3 months after the closing date of the application that you applied for. After the ATSAT test, if you pass with a 70% or higher, you will be given a chance to select 2 states as your geographical preference and whether you want En Route or Terminal or whichever comes available first. We have a selection panel that convenes once a quarter to make their selections, so you will not receive the geographical preference e-mail until approximately 2 months prior to a selection panel conveying. At this time, we do not have a selection panel scheduled until after January 1, 2009. We will then create referral lists for the panel that will make tentative selections from that announcement. If you are selected, you will be contacted to get you set up for an interview and to attend a Pre-Employment Processing Center (PEPC) for your medical and security; this could take approximately 3 months after the conclusion of the selecting process. After completing the required medical and security examines, it could take up to several months before we could get you scheduled into an academy class. This depends upon the number of classes that we have scheduled and whether or not they have been filled. As you can see, the hiring process is lengthy, so your patience is greatly appreciated.
