Boris Badenov
Fortis Leader
One thing I know about bird strikes is there’s always blood. I don’t see any blood.
Same source (ie. Not Me), but that must have been a suspiciously bloodless Condor, if accurate, etc. etc.
Birds aren’t real.One thing I know about bird strikes is there’s always blood. I don’t see any blood.
I defer to your knowledge on these things (and that makes a lot of sense). I was thinking maybe a drone. Whatever it was, holy crap.
I hadn't considered drones as it was reported as a bird strike. But @Wardogg is correct, even a glancing blow will make a bloody mess.One thing I know about bird strikes is there’s always blood. I don’t see any blood.
Found an owlHonest question: What's the most interesting world traveler you've found on a walkaround? Couple years back the tech guys in BOS pulled a live iguana out of the left main landing gear bay doors when something was making an odd not-quite-PTO-barking-noise taxiing in. That got a good gathering of rampers.
PSA had a CRJ700 named Bambi after taking out a deer passing V1 in Charlotte.
Sadly Bambi was the aircraft that went down in DCA.Honest question: What's the most interesting world traveler you've found on a walkaround? Couple years back the tech guys in BOS pulled a live iguana out of the left main landing gear bay doors when something was making an odd not-quite-PTO-barking-noise taxiing in. That got a good gathering of rampers.
Nope. Not all of them end up in the Hudson either.Do most bird strikes involve a fire and thousands of gallons of high pressure water being sprayed into the engine though? Or foam or whatever
I don’t know if I can handle all this speculation.Same source (ie. Not Me), but that must have been a suspiciously bloodless Condor, if accurate, etc. etc.
I was inferring, pre-coffee, that this one took birds in both motors and was able to get it back around the patch. Also why airplanes should have three engines, minimum.I was more inferring the blood being washed away by the fire hoses
Not my pic but if this is the one that bird sure had sharp feathers...
Yeah good point. Might be the case.I was more inferring the blood being washed away by the fire hoses
An Alaskan Guppy hit a bear landing a few years backHonest question: What's the most interesting world traveler you've found on a walkaround? Couple years back the tech guys in BOS pulled a live iguana out of the left main landing gear bay doors when something was making an odd not-quite-PTO-barking-noise taxiing in. That got a good gathering of rampers.
