Autothrust Blue
“If you jump on my shift, that’s just rude, man.”
That would be great if it was actually true, but it really just is not the case; the repeated line of Boeing was existing procedures were adequate to prevent this calamity and the emergency AD merely reinforced the importance of the Runaway Stabilizer memory item while mentioning that all manner of flight deck effects (“FEEL DIFF PRESS?!”) could indicate that the single-string alpha input to the FCC was garbage and firing the stab nose down intermittently (important, for fault recognition) but vigorously.Then there was a bulletin that clearly explained MCAS, what it does, and what to do if it ever happens again.
It ignored that:
1) this specific malfunction was an intermittently but rapidly moving stabilizer that
2) not a single crew in the world had seen in training which
3) is how you run to the limits of expertise and that’s not a good place to put an airline pilot and
4) did I mention they did this on single-input alpha with no comparing and
5) failed to tell ANYONE flying these things about it before the first time it hurt people?
Put more shortly, basic knowledge about pilot performance was ignored, among the other engineering problems.
God it pisses me off every time I write it out.
