So will the 175, as long as you stay fast.I remember the 727 Gear down full boards would just fall out of the air if you needed to get down asap.
Converting burned jet fuel back into heat for a second time, yay!
During my brief time on the 320 one of the things I had to get used to was slowing down and getting down. With the speedbrakes out Vls would shoot way up to the point of having to get Flaps 1 out, often well above Green Dot so that I could even select the speed I needed.
I really love using idle, flaps 2 + boards…then we all laugh at AS, and do SJI pilot stuff.Um...that's the 737. I was always told Idle Descent at 250 knots you'll get 1700 feet per minute. Add speed brakes and you get 1700 feet per minute and vibration.
In LAX, coming in from the east…YEP!You prob also use F10, you dangerous safety violator! Maybe even pop F40 for a second then back to 30......
No 40–>30. Need to do more 40’s, 15 and 30 are where I’ve found some pretty good landings
VLS is more akin to an AOA indicator in how it works. It will change as you load the wing, add or subtract spoilers, etc. you probably just never saw the true effect of the speed brake. It’s also way more conservative than a low speed cue.
Use flaps 40 all the time at BUR, SNA, MDW, and SAN. It was more of a pain when the max additive was +20, now at +15 it give more margin on gusty days, especially in the 700. Speaking of that thing flaps 10 works great since it gives you full extended on the slats.
The flaps 40 back to 30 trick works well also, for us we just have to be in landing configuration by 1000’ AFE.
I do most of the flap 15 landings in Denver in the summer when it’s really hot and you get the approach climb limit bleeds off landing required for flaps 30/40 message. Flaps 15 fixes that.
For me I liked landing the 300 the best, it hand flew nice. Too bad it was like a flying hot port-a-potty around.
Never heard of SFP, full slats at 10 on the 700, 25 on the 800/MAX8.That depends on whether it's a SFP or non-SFP. With SFP, it goes full extend beyond flaps 25.
You don’t have to be a fan of it. It still works good, lasts long time. Just another tool in the box to make things work in a dynamic environment.Not sure I'd be a fan of going to flaps 40 and then back to 30 to get yourself on profile. IMO if it was that bad you needed that extra crutch, you should have probably managed energy* sooner.
So you’ve never been left up high before? May we all be as lucky.SFP = Short Field Performance
I'd think I'd encourage you to have configured sooner instead of NEEDING to go to 40 and then reverting back to 30. Had you thrown the gear out 30 seconds sooner, you probably wouldn't have needed to do this POOR technique. (And lets be honest, that's what it is - a poor technique).
I have never had anyone do this. The only time I have gone from 40 to 30 is because of a tower updated wind was more gusty/sporty and so we bought agreed 30 would be a better margin. I've never been in position to go flaps 40 for more drag to get back on profile, and then back to 30 for the landing itself. Boo.
Just a hypothetical since I don’t actually remember a specific time I’ve done this. Say you’re on the localizer from a ways out and start configuring at 3000 AFE, then due to crossing traffic below your told to level at 2500, so you slow and get the gear and flaps 15, continue to slow to target and get flaps 30 then continue down. Now you’re high but not unmanageable since you’re at target, just drop 40 to get back on G/S and then flaps 30 before landing checklist, configured and stable at 1000 AFE and if not just go around.
I’d say it’s more a poor technique not to use all the tools available to safely get things done.
Sounds like you just like creating your own “techcedure”. I used to fly with guys like that when I flew 135 charter.Boo for going 40 to 30 to fix an energy issue.
Perfect! I'm fearful no one got it sufficiently to give you an atta boy!I'm curious: is the green dot speed an operating limitation for you?
Ask yourself, the flaps will also blowback up at other settings so what difference does it make? If your high and at flaps 30 and over speed them they will come back up as well. So that’s a red herring answer.I have never seen anyone do it.
Ask yourself , when does flaps 40 go to 30 on its own? Blowback. You got too fast. On approach, it’s not normal to go full flaps and then back one notch. Again, just from what I’ve seen. I’d still say you should have configured sooner to avoid that situation in the first place.
You not knowing what SFP is for a 737, no offense, raises my BS (red) flag.
Not using them as speed brakes if your already on speed and just using them to increase descent rate.“Using flaps as speed brakes is not authorized.”
To me, sounds like exactly what you are doing by going to 40 to increase your rate of descent without increasing airspeed, and then back to 30.
