scooter2525
Very well Member
For blast off sure, won’t be stabilized on landing though. What a cool feature.Real pilots use dial-a-flap.
When your airplane doesn't have a default Flaps 15 detent, you better believe we do.For landing?
Because CC doesn't like it its automatically a bad thing.
You know, Ive flown with some guys who have done the 40-30 thing. Someguys just rerun the numbers for 40 and do that. It works. Nothing says you CANT do it... also the SFP thing, its just normal in our 800s so its not discussed.
Also, you (CC) must not have flown into MCO much when they are landing north, going to the east complex and they keep you high and fast and then dump you and say GOOD LUCK! with a 40 knot tailwind at 7000 feet 25 miles from the airport...
I miss the -10When your airplane doesn't have a default Flaps 15 detent, you better believe we do.
Also for preventing an overspeed VNAV if you get them out quick enough... Looking at you SWA software...
Bombardier certified the Q400 below 10,000ft with the windshield heat off…so high speed cue went from 272kts range (if I recall correctly) at 10,000ft, to 246kts at 8,500ft. Great F’in idea…we used to have a TON of exceeded high speed cues.I did hear from someone that Embraer decided to put the barber pole at 251 knots below 10k because that would be a great idea
