melax
Who knows at this point. Gotta try pretty hard or have a lot go wrong to crash a PC-12 tho.
Aeroflot 593 ?
I mean, if you do a power on stall and fight through the pusher to the full stall yeah. But to get to that point sooooo much has to go wrong….Doesn't the Pilatus have quite a terrible, wing dropping stall characteristic?
Yes, in certain conditions it does -- there's a video of the test pilots will full aileron input just prior to the break. It has a stall pusher for that reason. I have done a power off clean stall in the simulator, and it was as docile as any airplane I've ever flown. I have no idea how well or poorly that approximates reality.Doesn't the Pilatus have quite a terrible, wing dropping stall characteristic?
Acquaintance of mine did some flight test in it, says power off is really docile. The video of the wild break is power on and it looks like the airplane is torque rollingYes, in certain conditions it does -- there's a video of the test pilots will full aileron input just prior to the break. It has a stall pusher for that reason. I have done a power off clean stall in the simulator, and it was as docile as any airplane I've ever flown. I have no idea how well or poorly that approximates reality.
Takeoff rudder trim is way out to the right for that reason. The only time rudder trim is centered, is in cruise.Acquaintance of mine did some flight test in it, says power off is really docile. The video of the wild break is power on and it looks like the airplane is torque rolling
In Florida it would go something likeWhat’s truly amazing to me is caravan pod weights. I have personally seen a guy put well over two times the limited pod weight (limit is 1080), load the airplane full of villagers, top the mains, and blast off…
It is terrifying that this was basically industry standard for awhile up here.
Inexperience and over-reliance on the autopilot "saving" him.That was because of iced up wings, right?
The NTSB report is suspiciously missing from the docket system.
I think this is at startup. They've got their McDonald's out while it's still lukewarm.This image was posted on FB yesterday at 9:59 a.m., which I’ve cropped. I assume it’s from the outbound flight. What does the panel indicate?
A CVR and LDR (lightweight data recorder) with underwater locating beacon are standard equipment.Obvious question - but what’s the CVR or data recording equip they could fish out of a PC-12?
I flew it for a living too. Did you ever actually stall it?I wouldn’t call any stall in the PC12 docile… Once it stalls it doesn’t want to fly again. Takes some finesse and like others have said, the torque from adding back that 1200 HP will put you right back into a stall. Been 5 years since I’ve flown it but I do remember stalling it would be quite undesirable.
Yes that was Florida. This is the other one.Thats the crash I referred to, that was Florida right? He said SD? I’m curious what iced up Pilatus accident they’re talking about.
Hopefully this isn’t utterly tasteless, but my sense of humor is somewhat tickled at the idea of a last meal being McDonald’s.I think this is at startup. They've got their McDonald's out while it's still lukewarm.
#MericaHopefully this isn’t utterly tasteless, but my sense of humor is somewhat tickled at the idea of a last meal being McDonald’s.
