jtrain609
Antisocial Monster
EXCEPT! Those regional guys didn't take a 757 from KIAD to EGGL.
The hardest part about ETOPS is staying awake.
Maybe, or maybe they flew for Silver out of FLL to Grand something and back 4 times a day...
its not a one size fits all thing, im just saying, the lower the time the less experience, it all comes down to pointing and saying "hey, maybe there is a higher risk factor there" Will it work out, most likely.
And Jtrain- its not like I just joined the pilots club last week.
And figuring out the rest break times.
Rest Break Optimizer
Crew Rest Optimizer is a comprehensive application to calculate pilot rest breaks and help crews optimize break and work schedules. • Multi break patterns and options are available with just one tap. • Only four entries are needed to generate a break schedule. • Changes to any input...apps.apple.com
Does help having lots of engines. I remember a number of years back one of our Falcon 2000 LX was coming back at night from I think Hawaii, had an oil pressure issue right at the ETP. Decided to shut the engine down as it was about to stop running, drifted down and had to relay it all through other aircraft. (pre CPDLC stuff) . Talking with one of the pilots a few weeks later he said he still couldn't find the seat cushion that was sucked up his hole. He said it was a bit nerve wracking. Apparently owners wife slept through the entire thing and never knew anything happened haha.
I see what they did there.I use ZZTrop (which I assume is "sleeping in the tropopause"). Mostly works well.
…what!? ZZ Top?I use ZZTrop (which I assume is "sleeping in the tropopause"). Mostly works well.
Seriously. I am terribad at math. Use the app I linked. It is ridiculously easy. Provides lots of great info too. Like showing the times in both local departure time and Zulu.I suck at math, but I just take the enroute time minus 90 min (time to TOC and then 1 hour prior), divide that by the crew, and start the first break 90 min in. My cross check is that the last Break should be 1 hour prior to our ETA
…what!? ZZ Top?
Or as one instructor taught me, "save the penguins"Whoaaa... dude... there's an app (actually like 15 apps) for that. Save those brain cells for important stuff.
Nerd.As a regional pilot, at least I knew how to correctly spell the code for Heathrow airport.
Nerd.
Also regional, charter, CFI etc, other airline I don't care, I still think people flying around as Captain without much experience in the airframe is dumb. I know it happens...
I didn't call out anyone. Get off the butthurt train.Nerd?
If you're gonna call out regional pilots for not having flown KIAD to "EGGL" then make sure you get it right.
I literally said they are not flying Dulles to freaking England. How is that "Calling out"?
