Roger Roger
I am le tired
Cmon man you can't lead us on like this.From what I saw, neither the wind/wx nor the usual hazards with the 6 circle 1 played a role in this.
Sometime after passing TORBY tower queried the aircraft if they were circling to 1. The aircraft began the circle with a tight turn about 1-1.5 miles from the approach end to 6 at around 500ft. Looks like they forgot they were circling and tried to do it last second. Should have gone around.
Does everyone normally circle early from 6 to 1, making it a sidestep-style dogleg to final, or can they overfly 6 to about midfield, make a right turn to south, essentially entering a right downwind for 1, ad proceed to land from there? A circling maneuver that's almost like a modified overhead.
Why would it cause major problems? Do they frequently have aircraft land 24 and 1 simultaneously? I'm assuming it would be easier to sequence airplanes, modify their breaks over Ry 6 to 1 downwind based upon in trail separation. Unless that somehow creates TCAS conflicts for EWRYou would cause major problems if you tried that. We did ILS 19 circle 24 today and as we were turning final there was another plane crossing the final fix on 19 starting their circle. They keep you tight
Sent from my SM-G900V using Tapatalk
What's the difference for sequencing in an overhead circle to downwind, versus circling like they currently do?There's never people landing 24 and 1. But to make break to downwind from 6 to 1 work we would have to run like 10 miles between arrivals.
Interesting. So they run what, 3 miles during 6/1 ops then?They amount of time they're spent going slow in the pattern.
I wouldn't think it would be that much of a problem. Granted they wouldn't be flying a fighter-style overhead in terms of tight spacing between aircraft; but a 6 overhead style circle to a 1 downwind is still a diverging ground track, that I would think tighter than 10 miles could be done, or even speed restrictions at certain points on the 6 final in order to not have to extend the turn point to the downwind beyond the midfield of 6/1. Would that not be workable?
I get my June schedule tomorrow, I'll be bugging you for a tour. I wrangled up a few friends from my shop that live here and are interested in visiting
I was kinda thinking that based on the traffic calls that were being given.
Edit: Compared to that video posted above, seems like this turn would have brought them inside the stadium, not outside.
The problem is they are still afforded IFR separation while in the circle, so visual separation can be handy, but it can't be counted on. If all of the sudden they canceled IFR, overflew the field and entered the right downwind, then your suggestion would work, but no one is going to cancel their IFR at pattern altitude at TEB.
They were almost even with the approach end to 1 at the apex of their turn. Way way way late. Couldn't tell if they tried to turn back to line up with 1, which might have been when the stall and spin happened.
Almost even with the approach end of 1 while coming up 6? Perfect position to start a right turn to a right downwind southbound for 1, ATC allowing, of course. Wouldn't have hurt to request that or ATC to have offered it, as that would've been an easy out from the square corner they were now in.
I have no Tower experience so I don't really know what they could or couldn't have offered, but really for that situation they're best bet by far would have been to just go around. All this is assuming they just forgot they were going to be circling and were thinking straight in 6.
Ah. Makes sense. Although maintaining an IFR while merely maneuvering to land in VMC (assuming no other prevailing Wx) makes little sense. I wonder why they don't do similar to mil. In a mil pattern, when in VMC with prevailing VFR wx;at many bases, your IFR is often cancelled automatically once you enter the pattern to land, whichever way you do it....from a visual, circling off an instrument approach, etc, if there's no chance of you re-entering any Wx. Done that way so tower doesn't have to deal with IFR separation. Even if someone overshoots a runway, they can be resequenced while in the pattern and remaining with tower. Unless TEBs tower airspace is too restricted or too tight to do so, that's always possible.
Honestly listening to the recording for the whole 30 minutes leading it, it makes me wonder why they don't just land 06 and depart 01. They could probably push more departures that way. Landing a Lear in a 30 knot 50 degree crosswind should not be that big a deal with 6000 feet of runway. They do it at my airport all the time.
