Al Bundy
First off- it doesn't take a power increase to tank the engine. This is a common misconception. Most engine failures occur during a "power change". That can be an increase or decrease. We typically see the failures during the second segment of the climb. Reason being is if the engine is wounded, it's probably going to be even more injured during the temperature change from being hot on the previous flight, cold during the turn of offloading pax, then getting hot again during the takeoff.In the 10 short years i have been flying a CFM-powered A320 (as well as the 10 prior years in turboprops), climb thrust has always been less than takeoff thrust. Even in flex.
That's why it's called "Thrust REDUCTION / acceleration altitude"...
I too belive that engines are more likely to fail at initial power up. I just doubt that evidence supports an increased rate of occurrence with flex vs TOGA. Just a guess on my part. I wouldn't know where to look.
As for if the second segment is a power increase or decrease, depends on your operator/performance engineer guy/how the airline wants to run their engines. Having flown both the comfy Airbus and the noise machine 737...
Fly a CFM56 on a 737NG with CLB 1 default after the TO power setting (Flexed aka "SEL TEMP" on Boeing) you'll get a noticeable increase in power setting, especially when your SEL vs OAT is a large split. Part of the logic in this is the NADP is complied with best by getting the aircraft as high as it can get as quickly as possible, in an effort to reduce the noise over the ground. Add in what some refer to as a "Close-in" and you get even better results.
Other things to consider is that an engineer may feel that the efficiency of the aircraft comes by getting it as quickly as it can get into the upper altitudes and cruise in an effort to save fuel.
Interestingly enough, if you dig deep into the perf engineers graphs, there is a power reduction that happens fairly early in the climb. Simply put, this is due to the loss of thrust an engine produces as it gets higher in altitude.
Next time you fly the A320 note the % when you click back to the CLB detent. Then look at them again later in the climb. You'll see they steadily increase. This is in compensation for the loss of thrust in the thinner air.
Engines fail when they are going to fail. However, TOGA puts a lot more stress/temperature change on an engine than reduced does. TOGA also gives more chance for a "burp" in the engine than a reduced power setting gives. I like reduced. Cringe when I get a "TOGA TAKEOFF REQUESTED" message from mx control.
