ASpilot2be
Qbicle seat warmer
We are approved for intersection departures. But us and Ravn us 7L/E in Anchorage. We can go out at max weight and sometimes reduce from there.
I think you'd be hard pressed to find an operation that is prohibited from doing them. If you can't run the numbers you should have never made it to the cockpit.We are approved for intersection departures. But us and Ravn us 7L/E in Anchorage. We can go out at max weight and sometimes reduce from there.
I love discussions with the "Full length or bust" guys:
"So, I guess you want only TOGA numbers too, huh?"....
Have fun with that.
"Cleared for takeoff, intersection xyz'
"Unable"
"Is it for performance reasons"
"No, I just don't feel like it because some guy once told me not to"
"Ok, make two left turns and hold short of Yankee, you're now number 20"
Qatar likes to do intersection departures in MIA.
Full length would result in de-rating rather than being anywhere near TOGA power, and the chance of an engine failure would be reduced by taking full length.
Additionally, some engines which are maintained on a "power-by-the-hour" program might prove to be more economically operated by taxiing 2 minutes up the hill to save from doing a full power takeoff.
I think the key thing in this whole discussion is that there are really two types of intersection departures.
One goes from "plenty of runway" to "still plenty of runway."
Another goes from "plenty of runway" to "thousands of feet less runway."
The way I think of it though, is that I'm fine with an intersection departure if it still feels like there's plenty of runway. That may mean tossing aside the numbers for an intersection departure way down the runway and sticking with full length, even if the airplane can do the short field version.
Nick, I respectfully disagree...
While I follow your logic, I don't believe this is factually supported.
This is true. However this is not the concern for most of the "Full length or bust" guys I've encountered.
In the 10 short years i have been flying a CFM-powered A320 (as well as the 10 prior years in turboprops), climb thrust has always been less than takeoff thrust. Even in flex.
The -90 had a derated climb setting. Generally only really used it when doing the "auto cutback" departure out of SNA.
It is also supported by experience and by a rather nice gentleman from GE who was good enough to come over and give us quite a nice talk about their engines.My understanding is that what Nick is saying IS factually supported. Engines don't blow up at V1, they blow up at the application of takeoff power, or in the alternative, when you select climb thrust. If you did a flex takeoff, then your climb thrust will commonly be above your takeoff power, and that's when the engine decides to knock off for the day.
I've been taught this as long as I've been flying turbine engines around.
In the SAAB we can reduce as low as 76%,but at 1000 feet we set the power to 100% or whatever the chart calls for.In the 10 short years i have been flying a CFM-powered A320 (as well as the 10 prior years in turboprops), climb thrust has always been less than takeoff thrust. Even in flex.
That's why it's called "Thrust REDUCTION / acceleration altitude"...
I too belive that engines are more likely to fail at initial power up. I just doubt that evidence supports an increased rate of occurrence with flex vs TOGA. Just a guess on my part. I wouldn't know where to look.
