Keyword in his post being high bypass turbo fans. Not sure where you fly, but I'm going to make a WAG and guess where ever you work only operates low or medium bypass turbofans.
I might be bad at reading, but that data is for uncontained engine failures, not ALL engine failures. Engines stop working for all sorts of reasons. Maybe the fuel pump decides to knock off for the day, or maybe the oil is French and decides that it's time to become liberated from the engine.
I don't know that either of the engine I've flown have EVER had an uncontained engine failure where parts grenade out of the engine.
Every jet I've flown has had a high bypass engine on it, even the venerable EMB-145.
I try to be a good neighbor. Especially since I live in the neighborhood. I don't appreciate the supersonic tips at 3am, especially when you actually make more thrust with them subsonic. The initial prop speed is to get on step on the water, not for climb out. You really should reduce the rpm at like full throttle plus 5 seconds.Well this is 2 parts.
1) Myth that reducing throttle will cause a dramatic increase in CHTs. Not true for all aircraft. The idea is that the last 1/2" of throttle is actually just increasing the mixture, and that when you reduce throttle all you're doing is prematurely leaning the mixture and causing CHTs to rise. I could find no evidence of this including asking Lycoming and Continental (they deflected the question). Testing it in a single engine aircraft has a ton of variables to control - if you try one takeoff at WOT then another takeoff at reduced throttle, your engine is going to be warmer to begin with, OAT may have changed, aircraft weight will have changed, etc etc. I tested it in a twin by reducing one engine after takeoff and found that the engine at lower throttle was dramatically cooler (like 100º cooler) than the one at full power.
2) "Detonation zone". Simply not going to happen on a modern engine running 100LL. The temperature and pressure required to detonate 100LL is so high that there is just no way for the operator to do it accidentally. Nor can any engine pass certification without proving that it can run through its entire operating range at max temperature without detonating.
As for reducing power on takeoff in a single engine, I would say leave it at full power until at least 500' or a safe altitude then reduce. A piston plane doesn't have the power of an airliner, pistons aren't nearly as reliable and you've only got one of them. #1 priority should be getting to a safe altitude as quickly as possible to minimize time low to the ground. Who cares about obnoxious noise on takeoff? Once you're above 500' or so you can pull back the power some and it's not going to hurt the engine or cause detonation.
I do know that on the TIO540 the quicker you get from takeoff power to climb power the lower your CHT stays.I try to be a good neighbor. Especially since I live in the neighborhood. I don't appreciate the supersonic tips at 3am, especially when you actually make more thrust with them subsonic. The initial prop speed is to get on step on the water, not for climb out. You really should reduce the rpm at like full throttle plus 5 seconds.
As far as CHTs, well, from repeated attempts, my engine runs 80-100F cooler taking off at ~23" MP than 30". And since at full power it takes ~300ft to take off and at that reduced power we're talking all of 500ft on a 2000ft+ runway it's not a big issue. If length might be and issue, sure full forward on the yoke, full power, 1/2 flaps, etc. But that isn't the norm. Also I have issues of the preheat only getting the oil to 100F or so, which at full takeoff power will take the oil pressure up near 100psi which is the red line.
As far as a place to land in case of an engine failure, you're really just better staying on the ground if you want to think of that. You might survive the landing, but you're still going to die.
CHT is the wrong indicator anyway, EGT is where you'll see the difference.
Real engines have weak oil rings, slightly warped valves, carbon buildup, and timing that's a little off, and people do crazy stuff like add marvel mystery oil to their fuel to "prevent lead fouling." And install plugs that they found in the garbage.
Stock 152 compression ratio is 8.5:1, sparrowhawk 152 is 9.7:1.
True, but EGTs aren't what people normally look at to determine engine health. Engines are usually limited by their CHT - under 400º typically.
All of that stuff (well - minus the marvel mystery oil) would reduce compression and reduce the likelihood of detonation wouldn't it? Hot spots are the one thing I'll give you.
But my last car was an 11:1 compression ratio and it took 93 octane. I could run it up to 6400rpm and never get detonation. How would a relatively low-compression aircraft engine running much higher octane fuel ever detonate in normal operation?
Because your car has variable ignition timing and EFI. Not tech that the Romans would be familiar with.But my last car was an 11:1 compression ratio and it took 93 octane. I could run it up to 6400rpm and never get detonation. How would a relatively low-compression aircraft engine running much higher octane fuel ever detonate in normal operation?
Did you have to ask for it, or was it offered? I just don't really see the point of taking the intersection there and leaving thousands of feet behind you. No doubt its legal, but to save a few min of taxi time, it doesn't seem prudent to modify the standard departure point of the runway IMO.Finally, to the OP: I have done 17R/G in KAUS many times in the Airbus. As long as we have the numbers, works good, lasts long time...
We've also chosen to go full length many times for various reasons. It's all good...
In the 10 short years i have been flying a CFM-powered A320 (as well as the 10 prior years in turboprops), climb thrust has always been less than takeoff thrust. Even in flex.
That's why it's called "Thrust REDUCTION / acceleration altitude"...
I too belive that engines are more likely to fail at initial power up. I just doubt that evidence supports an increased rate of occurrence with flex vs TOGA. Just a guess on my part. I wouldn't know where to look.
What is the point of V1?Did you have to ask for it, or was it offered? I just don't really see the point of taking the intersection there and leaving thousands of feet behind you. No doubt its legal, but to save a few min of taxi time, it doesn't seem prudent to modify the standard departure point of the runway IMO.
As I said before, if any of my teammates are uncomfortable doing it, it's not a big deal to go full length.
