alaskadrifter
Landing gear operator
Try reading again, I believe the word "funny" was used.So Delta improved the airport facility and you are complaining why?
Kodiak puts Juneau to shame.Yep, Juno is so much worse than this place.
It may be. But I was just mentioning an airport worse than Juneau.I thought that was Quito.
It's like JNU was like the moon "Europa" that the monoliths didn't want the crew of the Alexi Leonov jacking around with.
(there, that should make some heads spin long enough so I can go refill my non-branded Marriott coffee)
Yes it is. check out this one at the 2:00 mark. And they touchdown on the thresh hold. You need every inch on this runway.I thought that was Quito.
And they touchdown on the threshold.
It's a high, short runway that required max performance. Or else:Why?
	I'd read that again because it definitely wasn't supposed to be taken seriously.Try reading again, I believe the word "funny" was used.
Hey, all I'm saying is I found it funny that delta gives 10k to keep the pool open, and next thing you know the city is buying them a 177k jet bridge (which delta then didn't use)
Probably like my fraternities philanthropy committee.
The cops come to bust a loud party. "Hey! You guys are the ones that did the Arizona March of Dimes thing? Oh hell, I'll swing by after my shift and do some shots with you guys, keep up the good work!"
Nearly happened to me on an Aerocontinente flight with a presumably drunk pilot and a close call into Lima for a midair.It's a high, short runway that required max performance. Or else:
Don't forget to reengage LNAV!Lemme guess, you're going to send me on the missed right before an RF segment, AMARITE?
Hopefully it's easier on FiFi than the Dash Trash...Automatic NAV engagement on fifi! Yet another reason why we are superior!
@Derg gets to conduct the RNP briefing next recurrent due to his display of deep knowledge here.![]()
