swisspilot
Screw the caravan, put the Navajo back in production
With what engines? The American market for those planes is dead, lots could be sold abroad but it would have to run on jet fuel, AVGAS is not as popular.
discovered the elevator control was jammed from the ice accumulation and he was able to control his descent only by adjusting power.![]()
With the diesel that Cessna put in the 182T.With what engines? The American market for those planes is dead, lots could be sold abroad but it would have to run on jet fuel, AVGAS is not as popular.
When I did my 208 sim they give you the same failure, it`s part of the syllabus.
That pilot is very skilled!
Either a turbodiesel or PT6s like the T1040.With what engines? The American market for those planes is dead, lots could be sold abroad but it would have to run on jet fuel, AVGAS is not as popular.
The Diesel in the 182 is heavier than the TSIO-520, but because of the lower fuel consumption, useful load over a given range actually went up.The problem with the PA31 for pax 135 is the altitude limitation. How did the empty/gross weights of the T1040 compare to the Chieftain? IIRC the Thielert 4.0 were heavier than the 540/541/520's.
Nah, the problem with the chieftain is parts support. If you want to go high, you need a different airplane, but you don't need to go high on those sub-100 mile EAS trips.The problem with the PA31 for pax 135 is the altitude limitation. How did the empty/gross weights of the T1040 compare to the Chieftain? IIRC the Thielert 4.0 were heavier than the 540/541/520's.
I would not advocate for turbines on unpressurized airplanes because the fuel burn is too high.
The PNav. which on paper had 425hp engines. On paper.Makes sense, I flew a Mojave and you could tell it was begging for turbine engines. The Brazilians built a Navajo under license with the -27!!!
Was there ever a geared engine on the Navajo?
Exactly. With a whopping 1200 hour TBO. For a reason. I'm not a fan of geared piston engines.The PNav. which on paper had 425hp engines. On paper.
Exactly, short legs don't really give the pressurized aircraft much benefit. Although even with the caravan it's amazing what a difference there is in fuel efficiency between 1000' and 8-10k.Depends on the mission.
We operate part 121, 5 unpressurized turbine airplanes (208,DHC6 and F406), on our sectors having a pressurized airplane wouldn't bring any cost benefit.
I don't know the 406 real well, but isn't it basically a turbine 402? If so I would imagine it was pretty comparable to the T1040.I bet the useful load of those 3 with 2 hrs fuel onboard is much greater than the turbine 'Jo.
No I meant that piston engines burn far less fuel at the low altitudes that unpressurized airplanes operate at.Depends on the mission.
