Question though, what could you do even with negative mission impact? Our stance is no patient is worth a single crew member. It defeats the purpose of what we do.
Completely agree. Just like in the fire department.....doesn't help a situation to, as a rescuer, end up becoming a victim yourself.
Where I see a large issue is exactly in this area though, however I can't say whether it's endemic, or only happens here and there. And thats where you'll get the crew (for example) who is faced with bad or rough environmentals......be it weather, dark night, area at night that is challenging, etc; and they get a call for X patient who a victim of X car accident.....again, just using an example. They make the call that its not particularly safe to go at this time, for the conditions I cited above, and ultimately for the reasoning you cite in your response above. All good, fair calls. Now, take the same conditions, same situation, but substitute the adult patient/victim, with now a 5 yr old female patient/victim. I've seen where there have been crews that...at worst.... have went ahead and launched in the same conditions that they wouldn't have before; and at best.....have considered and tried to find any way to launch and go, when they wouldn't have before, yet still ended up not going. This is one of those areas of the RW EMS side that no one wants to really talk about, so they go with the accepted logic of "no patient is worth a single life of ours", when in reality, they don't truly believe that deep down. But how do any of us really go about changing that, even if we could honestly identify it.
Second area is inadverent IMC. In the fixed-wing side, if you go inadverent IMC, big whoop. Who cares. If its not something you'll instantly be out of, then you climb, clear terrain, contact ATC, get a clearance (assuming you weren't already IFR). It's really a non-factor, generally speaking. Instruments is already what we do (I say we, being dual-qualed), so big deal.
Now take the helicopter that goes inadverent IMC. Chances are, the pilot has already been trying to keep under the weather to avoid it, so he's already very low level. In an AStar, he's in a helo that's not rated for IMC and is minimally equipped. Being a helo guy, instruments isn't really his thing (unless he's dual qualed), as weather avoidance is the key, both legally as well as for aircraft certification; so he's already all hands and elbows just trying to keep the bird upright. He's single pilot, to boot, with all these challenges going on. There's likely no ATC to contact to get a clearance, either being low level or in the middle of nowhere. He doesn't have the fuel to get to anywhere distant where he could shoot an approach compatible with whats on the helo; as fuel is a luxury they can't carry too much of if they want to carry a patient...and there's no speed to divert anywhere anyway that's even remotely distant. He's lost references to where he is, so descending out of the WX without hitting the ground or something attached to the ground isn't an option. In short, he's pretty screwed. It's very likely that if not prepared for an inadverent encounter or at least seeing it coming with some time to prep if only mentally prep; that bird is going to exit the WX straight into the ground.....likely shortly after having entered it. Make that even more shortly, if all the above is going on at night.
Difference betwen the two situations? Simply the nature of the beast of fixed wing ops, versus rotary wing ops; both in general, as well as within EMS itself.
