What's the prospective bases when the AA flying starts? Will it be the usual DFW, ORD, and MIA?
What are you guys hearing on your end about Horton's comment to the WSJ about the deal now being in doubt?
I may have read it differently but I read Horton's comment as something like "hey man I just work here!" And people are now saying "see!? The merger DID just undo what he did!!!11" There are so many things that could negate or void that contract...we'll see.
There was one small victory unrealted to bankruptcy court, the 5 used 175s are no longer going to AA.
So is that 5 more aircraft that will stay active in the Republic fleet plus the new aircraft coming in for the AA flying?
There are no Republic aircraft coming offline. They are just reducing the count to 47 because Air Canada couldn't get the 5 175's ready in the time frame that AA wanted.
Where will the 175s be based for AA?
I was wondering if CLE was going to transition to them as well.ORD at first, then other "east coast bases" possibly in the future according to the CEO. Which isn't a big deal since ORD is already a CHQ 140 base (which the contract extended for another year) and is pretty senior which means a lot of senior CA's will probably jump over.
flyinggreasemnky said:Well, considering CLE is only a 145 base and is for United, I doubt it. More than likely you will see it in DCA, LGA or JFK (possibly a MIA base). Of course, I'm sure BB will try to put some of it at one of our crappy outstations like CMH or IND.
IND and CMH are fathoms better then LGA or JFK, I don't mind DCA, good overnights, but terribly expensive
I thought they also did AA Flying out of CLE. Guess not. I heard they were going to be increasing the size of this base.
CLE is going to be one of the next bases to close as United is slowly winding it down. It is becoming nothing more than a focus city and CLE is only a base on the CHQ cert.
CFIT: IND and CMH are horrible bases unless you live there or live in a hub to make it easy to commute. I will give you that they are hundred times better than commuting to PIT, GSO or MCI. The problem, on the Republic cert, is that we have 5 out stations bases to support 3 hubs, 2 of which are already bases. You would see better quality trips and more commutability if they actually used the hub basing model. I bet once BB realizes he can get most of the senior people to leave if went to hub bases, the outstations will close overnight. (The rest rules may force that anyways.)
I see some of your argument, except the horrible part, they are decently easy to get to from most east coast cities. They are dirt cheap and as for the shuttle side, the trips are pretty good. (lots of 4 days with overnights everywhere) (unlike LGA where it is mostly day trips)
But I do agree with the "outstation" basing BB will try to, but IND will NEVER close because of managment and its shuttle's largest base....making CMH the only true outstation base.
