Ahhhh......so here we go.
Now, remember when I said I support this guy's decision to make the terminal decision he did? And I said once that decision was made, you're not coming back. You made your statement by your choice in an extreme and terminal way, and now you're done.
Seems he wants his job back now.
Im sorry partner, but it doesn't work that way. If you wanted your job back, then you shouldn't have hone down this road in the first place.
Just my opinion.....ultimately up to JetBlue though.
http://www.cnn.com/2010/TRAVEL/08/12/flight.attendant/index.html?hpt=T2
:yeahthat:
As much as I've defended his "exit", (he did remove himself from the situation), I do NOT think he should be allowed to come back. With an exit like that, one's permanent departure from the company and the profession should be a given.
What was the point of the slide when you could have done a 180-degree turn and WALKED out via the jetway?
He could have killed one of the ramp crew unloading the bags.
How, freak accident? I don't think the slide would have done anthing other than knock someone down.
That's just what the media is throwing about. After all the slide comes out at 3000PSI! Which coincidentally is the same pressure used in a compressed air cannister. If an inflatable rubber safety slide can kill someone on the ground then holy design failure.
