The numbers given to me work for me in the pattern very well. However I seem to be getting alot of straight in approaches lately, and am learning new power settings.This thread has made me realize just how much I need to learn, and try new stuff. It seems that at the private level, there's all these "guidelines"....power to 2,000RPM abeam the numbers, 1650RPM base, etc. In reality, none of these numbers mean anything, and are probably just used to give pre-solo students a starting point. I'm usually throttled way back miles out. Just how I learned. I guess that's also a good way to piss off ATC....![]()
I always try and get out of the way of bigger aircraft. Whenever the DC-6, PC-7, and Commander would come in, I would get out of their way.If your runway is greater than, say 4000 feet, please stop practicing short field landings when even slightly faster planes are in the pattern. It's all fun and games for you, but if I have to pour on the coals, that's another five minutes on the delivery time of the freight. They actually care about that. I know, I know, but they do. For the most part, controllers do a fantastic job of keeping the trainers out out of everyone else's way, but if I'm doing 250 five miles out, it's not for fun. Not to say I don't understand, I've been the guy in a 152 who gets offended that someone else is flying directly up my wazoo. But show a little courtesy. Yes, the runway is your's. No, services shouldn't be predicated on landing weight. But hey, CFIs, if someone is flying up your hindquarters, consider the possibility that it's not because they just think it would be fun to make you angry. Do what you have to, absolutely, but if you CAN switch to a shorter runway or make the first turnoff, do me a favor. Not cause I'm "better than you", just cause it's polite and isn't a hardship to you.
PS. I hasten to add that when the only aircraft in the pattern are capable of slowing down, do what you need to. You don't need to speed up for a Duchess or even a Baron, for the most part. A Falcon? Maybe let's make this one a go-around?
Power on or power off? Discuss.
I like to be power off when the mains touch, even in high-performance sleds just because I think the least thrust is best.
I always try and get out of the way of bigger aircraft. Whenever the DC-6, PC-7, and Commander would come in, I would get out of their way.![]()
No, no, no... You're doing it all wrong.Generally in the Citations we bring the power to idle at '50.
Red line the tach on the GS, until 100 AGL kill the power, hold pitch, flaps 10 at 105, flaps 30 at 90. Add a smidge of power for a second at 15 agl, land, make the first turn off 900' down the runway.
Thats how you can do 130 down the pipe in a 172 and not hold up traffic too much behind you.
I will have to keep that in mind when doing ILS approaches to ANC so I dont make Polar, Velo, and those fancy jet pilots mad:nana2:Red line the tach on the GS, until 100 AGL kill the power, hold pitch, flaps 10 at 105, flaps 30 at 90. Add a smidge of power for a second at 15 agl, land, make the first turn off 900' down the runway.
I wish you were my captain. I try to do that and he pushes 'em back up "so we don't flame out". :banghead::banghead::banghead::banghead:Power to flight idle at FL400.
Depending on the engine that might be a possibility. On the 35s the fuel computers keep the speeds up in the thinner air.I wish you were my captain. I try to do that and he pushes 'em back up "so we don't flame out". :banghead::banghead::banghead::banghead:
-mini
