"Any Traffic, Please Advise" by an Airline
I'm not trying to offload my responsibilities and frankly I take a little offense at the suggestion. What I am trying to do is get all the information I can.
Yes, by creating a burden for everyone else in the vicinity. You're maximizing your own benefit at the expense of the whole system. That isn't the way it's supposed to work, which is why the FAA has said "don't do this."
You play your proper role by announcing your position or activity and I'll play my role by listening to your reports. That's the way we're supposed to work together.
What I'm noticing is a difference in worldview between the jet drivers and us bugmashers.
We're more or less used to dealing with yokels who don't talk on the radio and maneuver in strange places.
Jet jocks are used to having traffic pointed out to them by ATC, TCAS, and 2 pairs of eyes. So when those aren't doing it, they holler out for anyone and everyone to tell 'em where they are. I can't say I blame you guys-there are plenty of bumpkins out there that don't use the radio, or don't use it right. However, I'd like to point out that if someone is ignorant enough to not hear your position report, not analyze your position relative to theirs, AND not make their position reports, the fateful words "traffic in the area please advise" are unlikely to make a difference. Clearly, said individual is either in their own little world or has no radio.
Having said that, if I think a particular aircraft is going to be an issue and I haven't heard from them in a while, I will call out to them specifically (Cessna at Gladewater, where you at?).
Regarding remarks on Gen Av...didn't a lot of you airline folks learn to fly in Gen Av? Why the hatin'?
Thank you for reminding me why I hate general aviation so much. Bring on the prohibitive user fees to clean up the airspace!
Now that's just a bit unnecessary. Making a blanket generalization and overzealous push to get rid of a passion I and many have to fly recreationally because you're not fond of how some, probably not most, and definately not all G.A. pilots make radio calls is a bit much.
Sorry, but it's a widespread problem. Pilots that don't use radios, pilots that don't bother to turn on their transponders, pilots that don't use proper pattern entries, etc.... If I had my way, the government would require all airports that receive airline service to have operating control towers 24/7 with radar service, and all aircraft would be required to have and use a Mode C transponder.
The two views are not incompatible. I find the phrase "any traffic, please advise" to be lame and to indicate a fundamental misunderstanding of the system. Agreed. Yes. I do not use it, as a general rule. Agreed. No. I self-announce and listen for others to self-announce, as outlined in the AIM. Agreed. Yes.
However.
1) I can conceive of situations in which I would use The Phrase (there are obviously lots of planes in the pattern and no one is talking or, say, there's one plane who isn't clearly in or out of the pattern who isn't talking and I'd like to know what he's planning on doing.)
2) I am not going to lose sleep over how other guys use the radio. It's simply a losing proposition no matter how you slice it. If you're part of the radio Gestapo, I pity you, because by definition there is always someone doing something wrong on the radio, since one Gestapo member's unmitigated Right is another Gestapo member's irredeemable Wrong. Because:
3) I simply do not accept the proposition that one's paramount obligation as a professional pilot is to see to it that the System works flawlessly by following every subparagraph of every advisory circular as punctiliously as possible. If that happens, great, and if I can do it without compromising actually doing my job, fantastic. But it's not the goal.
One way things can work better is if we all try to work together to avoid embarrassing aluminum waterfalls rather than carving out our personal fiefdoms and glaring slit-eyed over the battlements screaming "Those guys suck!" *
(*offer void for Civil Air Patrol) :)
I'm pro-GA but last week when it took me 7 hours to get in and out of Vail, Colorado because of at least 50 business jets coming in and out I kind of hated GA. I was behind a 757 who was also waiting a tremendous amount of time -- a ton of people were inconvienanced because 1 or 2 rich guys (multiplied by like 50) decided they were too good to fly first class. :crazy:
"Great, we're number 11 to start engines to join the taxi line."
Just for context:
When was the last time you flew into an uncontrolled airport (in VMC)?
An airport without a control tower (in VMC)?
Again -- both of you. Hypothetical situation:
You are not inside the traffic pattern but relatively near the airport to the northeast. I make my first position call and include the "ATPA" phrase. You conclude that your position is not a factor for my approach to the airport and make no call and continue on your manuevers. I enter the area and make my normal traffic pattern position calls but on short final a herd of elephants runs onto the runway and I have to go-around. This airport happens to have a company specific balked landing procedure that takes me outbound on a radial to the northeast to some intersection for a holding pattern, then back to the airport. My responsible radio call will be something like "On the balked, tracking radial 028 outbound" which may cue you in that I may be heading straight for your aircraft. You being a bright fellow would realize this and now decide maybe you need to tell me where you are. By the time you do so depending on your altitude and distance from the airport we already may be fairly close to each other and besides, there isn't much I can do to change course once established on the procedure. Also, perhaps there are other fellows less bright than you are who can not immediately put two and two together.
Had you reported your position, which you concluded wasn't a factor to me, I could have realized that in a go-around it would be a factor and then 1) expected you and 2) coordinated with you more quickly in the event of a balked landing, rather than have us both be surprised by the fact that there is an airplane coming straight at each other.
You're making the assumption here that the pilot entering the pattern is not making their own traffic reports. I personally go with the AIM recommended procedures, I try not to make up my own way of radio communication, but to each, his own. I also use the landing light, as recommended in the AIM, to which the owner of the aircraft has scolded me because they cost so much to replace, but that is a different story. I make my own traffic reports, as recommended in the AIM, whether no one has flown that day, and I'll be alone in the pattern, or if there are 10 aircraft in the pattern, I still say the exact same thing. When it comes to me avoiding other aircraft, I don't rely on my ears like so many of you advocate, I rely on my eyes. I do my part in following the recommended procedures, and should not be scolded for following the procedures. When it comes to avoiding other aircraft, has anyone else ever heard of "see and avoid". I realize sometimes other aircraft are hard to see, and I do use my ears to help me out, but they are a secondary means, not a primary means. I believe Steve pointed this out, that even though I won't respond to your "all traffic, report position", you will still hear me, within one minute, making a standard position call on the radio, as recommended in the AIM. Also, what makes you think that if a pilot, with a radio, is not making his reports, even has his radio on...if he is negligent (I hope I spelled that right) to not follow AIM recommended procedures, what makes you think he even has his radio on, and on the CTAF. And I do also look at whether you even need to know about me. IF you call 20 miles out, and ask for everyone else to report, how much good will it do for me to say I'm 2 miles north about to enter downwind, 15 seconds later "XXX traffic, cessna 12345 turning downwind runway 5, XXX". All I did there was add one extra transmission to the frequency that you would have heard 15 seconds later anyway. All of this is why I choose to follow the recommended procedures in the AIM, and not make up my own. At the same time, I will reply if an aircraft has a specific querry to me, like if they still cannot see me after I make my own position report, or something like that, but I will not reply to a blanket announcement.
Whoever responded that GA should go away and have user fees, apparently is stupid enough that they want aviation to go away. How will we get new pilot, and the next generation of airline pilots with user fees. As you suggest, GA would pretty much go away. How will people learn to fly then? Maybe we will just have people jump right into the 737 sims and learn to fly that way then, since no one will be able to afford to fly GA anymore
This next point is just a pet peeve of mine, and that is people that say "inbound for a 45 downwind". I much prefer to say "Inbound for a standard entry to downwind" I was flying with a friend once, who is a pilot, and I said my standard entry line, and he said to me "what is a standard entry, how do other pilots know what a standard entry is". I told him he might want to look in the AIM and then get back to me. I standard entry is a 45 degree entree, and I do my best to make it as close to 45 degrees as possible, even though some guys go with 30, 60, 90, I even saw someone once cut me off in the pattern making a 135 degree turn to downwind, and never made a radio call at all. It did upset me, but technically he can do it, since it is an uncontrolled field, since I wasn't lower than him at the time. A lot of people also do not realize, even though I do not do this myself, the only thing regulatory about a traffic pattern is the direction of the turns, everything else is only AIM recomended. Anyway, this last paragraph was only a pet peeve of mine
clestudentpilot:
In that scenario the pilot of the other aircraft was not in the taffic pattern or entering it. He was nearby the airport doing air work.
According to Ray's original post the airliner was asking the TOWER to please advise him of any traffic. He was not asking any traffic in the area to advise him directly.
I see no problem with this.
Seems to me that the one who's irresponsible and unprofessional is the pilot on frequency who wont respond to the request, not the one making it.
There are 6 airplanes in and approaching the pattern. Each is making standard self-reporting calls. A 7th doesn't bother to listen and makes the disapproved "any traffic" call. The other 6 ignore him, refuse to talk all over each other at the same time, and continue to make their standard self-reports.
You're saying that the 7th pilot is the "professional" and the other 6 are acting "unprofessionally" and "irresponsibly."
I guess you have a very different definition of those terms than I do.
But, hey, that's what "professionals" do.
I see one huge issue with this phrase. You're asking more than one person to respond to you at the same time. If there are three other airplanes in the area, and they all do what you asked, you're going to hear a lot of whistling. If you just said your position report, only people that could be a conflict are going to speak up.
This all reminds me how much I enjoy flying no-radio airplanes.
"Blocked!"
"Blocked!"
"You're on GUAAAARD!!"
"So are you!"
I'll make the request if I am approaching an uncontrolled airport and it is all quiet on the CTAF, yet the TCAD show's traffic in the pattern area. If there are position calls being made then I'll chime in with my own location/intentions and proceed from there. Sometimes the 'Any Traffic in the XYZ area Please Advise' call does provoke the desired response.
Even if you had some reason to suspect that there was unannounced traffic? I'll offend a controller, "violate the AIM",...heck I'll even risk sounding uncool if it will even marginally improve the odds of not digging any smoking holes.
Give me an example of you "suspecting" traffic. Do you get wild hunches or are you seeing something. I didn't say anything about not asking if the controller has the traffic that I see or see on TIS, and no I will not ask for a general picture of area traffic and tie up the freq for peace of mind.
Just two observations:
1. Some of the comments sound a bit like attempting to justify not following recommended procedures (avoiding 'any traffic...') by complaining about other stupid pilots who don't follow recommended procedures (position reports).
2. I doubt that this is the case with this group, but some comments sound like the pilot using the "any traffic" phrase is relying on a response. Some pilots will not respond to the request (I'm one of them) and others can't (no radios).
:yeahthat:
That really sums it up.
GA is wonderful. I've been in a pattern of three helicopters in right traffic and four airplanes in left traffic. That is impressive by itself but we made room for a straight in citation. These yokals you are talking about are far and few between. We bend over backwards to bring you in with out making you change course. GA is not a problem.
Just for context:
Can't remember the exact dates, but a few times in the last few months. We fly into several airports that have control towers that close earlier than arrival times. At Pinnacle we did it quite a bit into several different airports.
You assume that we "don't bother to listen," but this is because you're not used to our operations. You're used to putting around at 90 knots, but we come into the airspace at 200+ knots having been handed off to CTAF by the ARTCC relatively close to the airport. We don't have much time to listen. You can listen in on the frequency and make reports for 10-15 minutes while you approach the airport at a snail's pace. Doesn't work that way for us. We need a quick picture of what's going on, because we'll be joining downwind before you know it. With so many planes not using their transponder and making our TCAS useless, uncontrolled airport ops can be quite dangerous.
