Comparison<!--webbot bot="Navigation" i-checksum="28592" endspan --><TABLE id=table1 width="100%" border=1><TBODY><TR><TD></TD><TD align=middle>
TurbineAir Bonanza</TD><TD align=middle>
Standard B36TC Bonanza</TD></TR><TR><TD>Engine model</TD><TD align=middle>P&W PT6A-21</TD><TD align=middle>Continental TSIO 520UB</TD></TR><TR><TD>Horsepower</TD><TD align=middle>500hp</TD><TD align=middle>300hp</TD></TR><TR><TD>TBO</TD><TD align=middle>3,600 hrs</TD><TD align=middle>1,600 hrs</TD></TR><TR><TD>Length</TD><TD align=middle>29' 3"</TD><TD align=middle>27' 6"</TD></TR><TR><TD>Max Ramp Weight</TD><TD align=middle>4,068 lbs</TD><TD align=middle>3,866 lbs</TD></TR><TR><TD>Max Take-Off Weight</TD><TD align=middle>4,050 lbs</TD><TD align=middle>3,850 lbs</TD></TR><TR><TD>Standard Empty Weight</TD><TD align=middle>2,800 lbs</TD><TD align=middle>2,820 lbs</TD></TR><TR><TD>Max Useful Load</TD><TD align=middle>1,250 lbs</TD><TD align=middle>1,030 lbs</TD></TR><TR><TD>Max Useable Fuel</TD><TD align=middle>112 gal (750 lbs)</TD><TD align=middle>102 gal (591 lbs)</TD></TR><TR><TD>Payload @ Max Fuel</TD><TD align=middle>500 lbs</TD><TD align=middle>439 lbs</TD></TR><TR><TD>Certified Ceiling</TD><TD align=middle>25,000 ft</TD><TD align=middle>25,000 ft</TD></TR><TR><TD>Take-Off Runway</TD><TD align=middle>700 ft</TD><TD align=middle>1,400 ft</TD></TR><TR><TD>Landing Runway</TD><TD align=middle>700 ft</TD><TD align=middle>1,300 ft</TD></TR><TR><TD>Max Climb Rate</TD><TD align=middle>2,500 ft/min</TD><TD align=middle>900 ft/min</TD></TR><TR><TD>Time to Climb (25,000 ft)</TD><TD align=middle>15 min</TD><TD align=middle>45 min</TD></TR><TR><TD>Long Range Cruise (25,000 ft)</TD><TD align=middle>
225 ktas</TD><TD align=middle>
185 ktas</TD></TR><TR><TD>Fuel Flow</TD><TD align=middle>25 gph (168 pph)</TD><TD align=middle>16 gph (96 pph)</TD></TR><TR><TD>Max VFR Range (no wind)</TD><TD align=middle>950 nm</TD><TD align=middle>1,000 nm</TD></TR><TR><TD>High Speed Cruise (25,000 ft)</TD><TD align=middle>
250 kts</TD><TD align=middle>
195 kts</TD></TR><TR><TD>Fuel Flow</TD><TD align=middle>29 gph (194 pph)</TD><TD align=middle>18 gph (102 pph)</TD></TR><TR><TD>Max VFR Range (no wind)</TD><TD align=middle>820 nm</TD><TD align=middle>954 nm</TD></TR><TR><TD>High Speed Cruise (18,000 ft)</TD><TD align=middle>
225 kts</TD><TD align=middle>
185 kts</TD></TR><TR><TD>Fuel Flow</TD><TD align=middle>31 gph (207 pph)</TD><TD align=middle>19 gph (114 pph)</TD></TR><TR><TD>Max VFR Range (no wind)</TD><TD align=middle>750 nm</TD><TD align=middle>895 nm</TD></TR><TR><TD>High Speed Cruise (12,000 ft)</TD><TD align=middle>
205 kts</TD><TD align=middle>
181 kts</TD></TR><TR><TD>Fuel Flow</TD><TD align=middle>32 gph (214 pph)</TD><TD align=middle>19.5 gph (114 pph)</TD></TR><TR><TD>Max VFR Range (no wind)</TD><TD align=middle>640 nm</TD><TD align=middle>870 nm</TD></TR></TBODY></TABLE>
Note: All specifications are based on preliminary flight test data and are subject to change without notice.
