aloft
NASA operates U2s on photo missions.
NASA's TR-1s are used for atmospheric research, not photo missions.
Brilliant!!!!!! Simply brilliant!!!!!:rawk:Chuck Norris doesn't ascend to FL600, FL600 desends to him.
Just for clarifications sake, F-16s, or many fighters at all for that matter, do not meet RVSM requirements and can not go above FL280.
F18s' GPS/INS isn't FAA certified, so they can't use it for navigation, but they do...
Vought ASM-135 ASAT
ASATs were generally given low priority until 1982, when information about a successful USSR program became widely known in the west. A "crash program" followed, which developed into the Vought ASM-135 ASAT, based on the AGM-69 SRAM with an Altair upper stage. The system was carried on a modified F-15 that carried the missile directly under the central line of the plane. The F-15's guidance system was modified for the mission and provided new directional cueing through the pilot's heads up display, and allowed for mid-course updates via a data link. The first launch of the new anti-satellite missile took place in January 1984. The first, and only, successful interception was on September 13, 1985. The F-15 took off from Edwards Air Force Base, climbed to 80,000 feet (24,384 m) and vertically launched the missile at the Solwind P78-1, a US gamma ray spectroscopy satellite orbiting at 555 km, which was launched in 1979. Although successful, the program was cancelled in 1988.
I don't really understand the obsession with flying high?![]()
their only way of filing (afaik) is via TACAN. they can't do VOR since they don't have VOR... the GPS isn't legal (altough they use it) because the points can be edited in flight.Well, not completely the truth. Again, they can't *file* using GPS navigation criteria, but they can sure do it. I have the same situation in both the F-15E and the T-38C I used to fly -- you have to file from point-to-point using the standard radio NAVAID procedures. Once you get airborne, though, you simply "request direct" destination and you go for it.
Our GPS/INS is not FAA qualified since we can manually edit the points in-flight. Secondly, the real ILS in the hornet is setup on Navy freqs, not Airforce/civilian freqs. This means that the best approach we can do is a TACAN approach (we don't even have VOR). Well, actually, we use PAR's or ASR's all the time.
Interestingly of our navigational capability of those 60 waypoints: these are actually termed "targets" or "offset aim-points". We basically trick our computer to use targets as navigational waypoints. This is how we fly everywhere: we go from target to target. The hornet is designed for bombing, not for jetroute navigation. I guess in the 1970's, the Navy assumed we'd always use Tacan stations for navigation and waypoints for bombing... I guess they're wrong.
Your astronaut wings come when you break FL264 which is 50 miles high. Yup, I do believe a few X-15 pilots received this honor!
