Wow, sorry, been busy and completely missed your first post! Well, if you have any questions on it, let me know. I was the ALPA tech person for it, LCA on it and numerous other work. It is a nice flying airplane, just fly it all the way to the ground and don't chase the pitch on landing, use power for your vertical path control. You can quickly get out of phase if you try to use pitch to land it, you need to do more of a carrier approach, holding attitude constant and using power as required all the way to the ground. Ground effect has a big impact, so usually you don't need more power than what the autothrottles are programmed for, but any sort of gusts and you need to be on top of it. It is a legacy jet in that way. On the other hand, it is the most automated commercial jet flying, bar none, and the systems work really well. It is also fast, which I like, but sometimes if you're heavy with some gusty winds it throws ATC off (the don't expect that 180kt plus final approach speed!).
