I would imagine anywhere you have a lot of one in, one out airports it could be pretty common. It is here for sure.Other than doing this for instrument and CFII training, how often does unpublished holds in a C-172 really come up?
I'd prefer an autopilot that does what it's told the first time (yeah... I'm talking to you, KAP140)
I don't know how often you've had to hold for either 1) weather below mins or 2) its an uncontrolled field and someone else is on the approach (this is 95% of the times I have to hold) but of these two instances I almost always get a non-published holding instruction, unless the approach I want to do happens to have a holding pattern in lieu of a PT.Other than doing this for instrument and CFII training, how often does unpublished holds in a C-172 really come up?
Yup. "You're number two behind an Alaska jet just starting his approach, hold north of CLUCK on your inbound course, maintain 9000, expect further clearance at 15 past the hour"I don't know how often you've had to hold for either 1) weather below mins or 2) its an uncontrolled field and someone else is on the approach (this is 95% of the times I have to hold) but of these two instances I almost always get a non-published holding instruction, unless the approach I want to do happens to have a holding pattern in lieu of a PT.
The 480's ability to draw the full hold is nice but the other Garmins' ability to draw the inbound course still gives you a pretty good depiction that is a step above just a VOR.
What micromanaging? People have been doing it for years with a VOR without too much of a problem. Doing it in a 430/530/650/750/1000 has about the same amount workload plus a line for the inbound course. Entering enough data for the unit to draw either a right or left turn with a specific distance or leg time sounds like much more workload.It's better than nothing but in what can be a busy terminal environment the last thing you wanna be doing is micromanaging the airplane, especially if you're holding to prepare for possible weather diversions.
And it takes away so much of the real problem most pilots have with holds - visualizing the hold in relation to the approach to the fix for determination of the entry.
The real advantage of an EFIS that draws the full holding pattern is that typically with a GPSS converter it will drive the autopilot to fly the holding pattern.What micromanaging? People have been doing it for years with a VOR without too much of a problem. Doing it in a 430/530/650/750/1000 has about the same amount workload plus a line for the inbound course. Entering enough data for the unit to draw either a right or left turn with a specific distance or leg time sounds like much more workload.
Sorry. When you were talking about micromanaging, I thought you were referring to workload, so I was comparing them. One would hope ATC gives us enough advance warning to set ourselves up for the hold, whichever.method we use.You can do the programming in a lower workload environment well ahead of the actual hold.
Definitely!The real advantage of an EFIS that draws the full holding pattern is that typically with a GPSS converter it will drive the autopilot to fly the holding pattern.
What airframe? I've used the feature quite a bit on the G2000 and it works great, guessing the G1000 implementation will work very similarly when it arrives (I haven't flown an airframe that's gotten the new software yet).The newest update to the G1000 software had the ability to create your own hold but it was a gigantic flop so almost everyone reverted back to their previous version. It will be coming....someday.
What?Not gonna do it. Wouldn't be prudent.
"local knowledge" that Delta needs, no doubt.I would imagine anywhere you have a lot of one in, one out airports it could be pretty common. It is here for sure.
"Hold at so and so" .2 miles away from "so and so" is going to result in "Uh, give me a heading" 100% of the time.Sorry. When you were talking about micromanaging, I thought you were referring to workload, so I was comparing them. One would hope ATC gives us enough advance warning to set ourselves up for the hold, whichever.method we use.!
