SpiraMirabilis
Possible Subversive
Does anyone know how to program a unpublished holding pattern into either of these systems? For example, tell it to hold off the 180 radial 10 DME, left turns?
Create a user waypoint. Hit OBS draw the inbound course and then make sure you turn the right way.
He wants to put the racetrack on the map, and then fly it using NAV or GPS autoflight modes (or whatever's appropriate for your configuration). I don't think the G1000 can do this (you can't say hold at FUBAR intersection unless it's published), which is disappointing for an otherwise very capable system.
It'd be pure sexiness to be able to say to the box, "hold at FUBAR, left turns, 4 nautical mile legs" and watch it do its thing - But I don't think you can.
I don't know how you'd do that with any GPS unit. Unpublished means not in the database. You'll need to set the holding fix as a waypoint and then you can either hand fly it normally, or do it by setting the autopilot on heading mode and changing the heading bug manually at the appropriate times and fly the hold that way. Still no holding pattern display on the moving map though.
especially in the heavier applications (Mustang).
:rotfl::rotfl::rotfl::rotfl:
Updated software gives you a hold page
It is a common feature available on almost every FMS I have seen. Why isn't it "prudent"?Not gonna do it. Wouldn't be prudent.
