I work on airplanes with "100%" fresh air, I have never bought into that idea. I'm well aware that the bleed air is removed from the engine before the combustion cycle, but the machinations it's subject to before it is used for pressurization should disallow the fresh air moniker. An APU with a faulty oil seal in the compressor section is going to contaminate the entire ECS, not just the cooling turbine, the entire ECS. I can see swapping an APU and kicking the airplane out the door after a smokey smell in the cabin, but there is likely still residual oil in the ducts, cooling turbines that you might not smell but are still probably a hazard. This is why I want a Cub, none of this mumbo-jumbo, possibly just carbon monoxide poisoning to worry about.
