I heart the 210, but ours does not have Ice protection.If you want winter flying look at a twin. Like what doug said or a chieftain. Or forget the plastic toy plane and look at ce-210.
A nicely refurbed T210 perhaps?
I'll offer one word of advice...
quote]
Sound advice...thank you for the valuable insight!
Cessna 400 is a series of aircraft. Columbia is a aircraft manufacturer.
Forget the twinstar. At least until the thielert issue is resolved. It is an unmitigated disaster. I think the DA 40 XL may be an ok choice.Looking for thoughts on which aircraft would be the best selection for a cost effective air taxi concept operating out of the Midwest. Not interested in Eclipe 500s or VLJs per se. With the lack of FIKI certification on the Cirrus, would the Twinstar be the better choice in terms of dispatch reliability?
It is going to be a Rotax derivative. No thanksI wouldn't touch a Twinstar with a ten foot pole until they start delivering them with the new engine (certification expected summer 2009).
I "heard" from a Cirrus owner that known ice certification was coming.
I flew a DA42 in ice once, scared the living #### out of me. If I remember right the fluid reservoir was only 3 hours on high setting, we were on a 4 hour flight.
I think that they should find a way to keep the Thielert concept, just fix the gremlins instead of pretending like their German engineering is flawless. Hell if it meant doubling the fuel burn to 8-10 gallons per hour per side that would be fine on me.
I have about 600 hours in Diamonds, they do not make a good product.BTW, it's too bad that you hate Diamond. They really do make a good airplane, but your xenopohbia prevents you from seeing it. See RyanmickG's thread about new vs old avionics....same principles apply to airframe design and construction.
That info came straight from a Diamond RepWrong. It's actually based on the same Mercedes block that the Thielert is, with improved accessories such as the gearbox which as you probably know is a major problem with the Thielert models (both 1.7 and 2.0 motors). They are also trying to certify the thing with IO-360s which I think is retarded because with a doubled fuel burn, the IFR endurance is like 3 hours with a reserve.
Not to mention how badly my paycheck gets screwed every time one of the damn things is down for the "Mx De Jour"
No, I have been genuinely scared for my life several times because of Diamond, particularly when I started seeing those cracks in the wing.Doesn't mean it's true.
As for your failures and pucker moments, I suspect that your real beef with Diamond is more tied to this statement:
than to anything else.
How the hell do you last three hours? I'm done after 20 minutes if I don't bring a seat pad and a lumbar padI can't disagree with the seats statement. After 3 hours, I'm toast.
See my experience with Diamonds has been one of consistent issues, problems, and all too frequent failures.I have to say that the most scared I've ever been in a plane was in a CE-150 when I lost a jug and couldn't maintain altitude. Does that make Cessna a death-trap?
