Callador
RAS?
Acessible Aviation. We did a lot of the ALPS, (some IFS), and the Mil Comp stuff. You may have come to us to do the mil comp after you finished your flight program. A lot of the guys do.
RAS?
It has already been said, but I feel that knowing when MOAs are hot and the associated altitudes is really the ticket, instead of a blanket ban. The problem is that those GA pilots you are probably talking about, they probably don't know where to find those times (even though it is printed right on the sectional).
Sometimes it is really not practical to go around a MOA that is the size of a small state. See and avoid.
I agree. Just knowing the altitude is really key. We normally flew all over the areas covered by the MOA's. You sort of have to around GTR, but the thing is we were always below them. Times help too, but even if they are hot a little GA plane can usually fly under them. That isn't always the case, but as you mentioned, it is worth checking out the sectional.![]()
:yeahthat:
when i flew GA before i started military flying i was ignorant and didn't really think too much of it.....now, i'd never do it
I don't see why you should avoid an MOA that's NOT active. However, if you fly through one which is active, then you're playing with fire.
You may not get burnt but it's not a good idea.
I can only imagine what it's like for a guy training in an F-15 at high speed to have to avoid a slow flying Cessna that's flying around fat, dumb, and happy.
Before I joined the military, I would have told you to pound sand. Now that I've seen both sides of it, I can tell you that you won't find me flying GA aircraft VFR in an active MOA.
How would you ever get anywhere in Florida if you didn't?
You didn't really get your charts out and check, did you?
Then my students look over at me as if I am being to anal retentive about flying into hot MOA's, kind of backing me into a corner if you will.
Alright bad choice of words there, what I mean to say is I often get the question of well if their flying through active MOA's then why can I not? because it keeps me from flying all the way around sometimes if you cant get over or under, well I tell him it is safer that way(so we don't end up food for an F16), and I get "whatever will do it my way when I get my license", thats what I meant, kind of an indifferent attitude from the student.
Area 1 and Area 2 in the panhandle area certainly is an example. Not so much fast jet traffic as T-34's and some T-6's. The Texan's operate mainly above 10k with the 34's from the surface to 10k or so. I had quite a few see and avoid situations but being in the mighty, slow but manueverable T-34, not too much of a problem...if seen of course.
on another note, i miss the ice cream and thai foodHere is a picture that you can paint for your student. I'm out there in the MOA, a student on a solo in a jet that is very hard to see from a distance, in a break turn nose low descending down to our training hard deck (10k) at 400+ KIAS, pulling 6-7 G's, looking through a soda straw of vision grunting through the G's and spending most of my time looking over my shoulder at the guy trying to take a shot at me. He does, and while still looking at him, I reverse almost pure vertical, still watching him, and we start weaving vertically up to nearly the top of the MOA (we gain 5-6k almost instantly in this maneuver before we start slowing down). I see another opportunity to get away, and piroutte right back into him and go shooting back down to the deck. Meanwhile I have really never once stopped watching him, and have certainly not scanned the area for traffic. Did I mention that we don't have TCAS or radar? Did I mention that we are covering many square miles a minute and essentially using the entire area of the MOA (both vertically and laterally) to do this? If that doesn't paint a clear picture to him of what goes on, then I guess nothing will.....or he just has a death wish.
Tell you're student to look closer.......
That's my old stomping grounds, and the airway doesn't run through it. The V66 airway is capped at 13,000. Tombstone C starts at 14,500 (IIRC) because it was the high airbridge between Tombstone's A and B. Tombstone's A and B went down to 500AGL, because those were both A-10 MOAs we used to use often, but C existed in order to cross between the two, OR to do high air-air work and have one continuous MOA, yet STILL allow for aircraft to go IFR out of Douglas to the northeast underneath.
