fo4ever
Loser.
Although, I might be back. The damned FO almost got me convinced to bid MSP MD90 captain.
Tough room!
Was the FO that bad, or actually using logic and wisdom?
Loser.
Citations without FADEC use a 85% N2 switch which will auto stow the spoilers no matter what else is happening. The 85% switch also starts pre-pressurization. Need to recycle the switch to deploy spoilers, and have WOW in ground mode. FADEC airplanes use TLA to coincide with N2 at 85%. The 650(III), 750(X) and 680(Sovereign), are different because they use a handle for speedbrakes with full travel being ground spoilers. Those airplanes might try to retract spoilers if WOW input is lost, I forget. I don't think the spoilers would retract in a bounce on any of the airplanes with spoiler switches.
Oops I just read the part when you asked about AUTO ground spoilers which no Citations have. Duh
He was just junior to me and wanted me out of his way I think!![]()
At Southernjets, you are required on the the 88/90 to LOOK at the handle to see that it is back, and staying back, before you say "spoilers up". Just hearing the sound of the handle is not enough.
Loser.
These are good. Again, to stay on topic, the question is:
If a [your part 25 aircraft type] lands and the speedbrakes deploy automatically, and subsequently bounces into the air - and the pilot advances power - and the airplane touches down again, will the speedbrakes deploy again automatically?
Not for long!
747s (Classics and 400s)
Ways the ground spoilers deploy:
1) Armed in the air and the aircraft touches down
2) Thrust Levers 1 or 3 at idle and 2 or 4 in idle reverse
How they close on the go around:
Thrust levers 1 or 3 advance above idle
Subsequent touchdown, if the handle isn't armed, they deploy when 1 or 3 is idle and 2 or 4 is idle reverse.
Have a Merry Christmas.
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
Merry Christmas to you too. Do they disarm with the throttle push after initial deployment on touchdown, or do they stay armed?
Loser.
The handle disarms, but the deployment will still be done via the TR lever.
I guess that'd be a semi-automatic deployment.
So if you pull the reversers, the boards come with them?
