For transport aircraft equipped with auto ground spoilers:
If, after initial touch down you advance the throttles as a result of a bounce or to go around, do the autospoilers stow, but remain armed, so will deploy immediately upon closing the throttles when on the ground, or do they disarm?
Please state your aircraft type.
Thanks-
Specifically, if the spoilers have extended, and you bounce and apply some power so they stow, and then subsequently touch down and close the throttles, will they extend with no other actions, or do they require manual extension at that point?
Excellent questions!
On the 88/90 DC-9, if you advance the throttles to go around after the spoilers deploy, they will retract AND disarm. It it based on throttle position. If you touch down again after you advanced the throttles the spoilers will have to be manually deployed. Up back, and up.
If you become airborne again after the spoilers deploy, they will STAY deployed unless you advance the throttles to go around, approx. 1/3 travel.
If you go around PRIOR to touchdown, they will stay armed.
Now, a Southernjets crew found out the hard way one strange caveat.
Imagine the bottom drops out on a approach and you cob the power a bit to catch the sink. You save it, but touch down with the throttles still above 1/3 travel, and bring them quickly to idle.
The spoilers will deploy and IMMEDIATELY stow and disarm; so fast it's hard to see the handle move aft and back forward. It has the same zip-zip sound of the normal spoiler deployment so if you're not looking at the handle, you may THINK they are deployed when they are not.
At Southernjets, you are required on the the 88/90 to LOOK at the handle to see that it is back, and staying back, before you say "spoilers up". Just hearing the sound of the handle is not enough.
