200kts below the Class B is a big reason for guys going into nearby airports. Cant forget that little rule
I get that one a lot. "Keep your speed up", "Roger, slowing to 200kts for airspace". I try to do a good job of advising that's what I'm doing if I was previously assigned a speed and can no longer maintain it because of the airspace. I do know there are a lot of guys out there that just blatantly ignore this and keep blasting away at 250 though, so I can understand why there is confusion and mis-communication.
how bout this...when coming into ATL. Slow when you're told, don't slow any earlier or you'll get another jet up your *** ..... Goes for anywhere actually as you're not the only one in the sky
OK to post MikeD?
Was I assigned a speed? If so, I will comply to the best of my aircraft's ability and if I can't, will do my best to advise if I can get a word in edgewise. If I wasn't assigned one, personally, I know the drill, I try to keep some type of SA about me that helps me know where I am in the conga line or just what number I am to the field (though I don't try to read your mind/do your job by making things up like some pilots like to do) and keep my speed up accordingly, HOWEVER, in the absence of an assigned speed, I will slow the airplane according to its profile, modified for how high/fast I was left (looking at you, Chicago Center). If I'm the least bit above the profile near the ground, it's a less than perfect experience trying to get the airplane down and it requires slowing, configuring, then descending or I will never be able to make it a stabilized approach.
Bottom line, IMHO, communication is key. If you need something, ask, and I will do the same. If it's a busy frequency, let me know sooner rather than later and I will do my best to let you know sooner rather than later if it's going to work out for me. We're all just trying to make it home safe at the end of the day.
