The seat has a full set of controls with full function. The loadmaster position is a rated pilot in command. After the pilots position in close proximity of the load, they pass control of the aircraft to the loadmaster. When the load duties are completed, he passes back (or forward actually) the control of the aircraft for forward flight. At all times, the primary responsibility is to cut the load if it gets tangled, shifts, or otherwise causes problems for flight.
