What accidents have happened where folks are over running the runway by adding 10 or 20 knots on their ref speed? Need a refresher.
Maybe I should say "hitting the TD Zone but have added 10 or 20knots?"
Hitting the TDZ isn't good enough at PCL as far as the FAA is concerned. Any other PCL guys remember the uproar the FAA got in when guys were landing in the TDZ, but NOT within the first 1000-1500 ft of runway? Since then, it's been company mantra to hit the 1000-1500 ft mark. Anything beyond that is outside of company landing standards and should result in a go around. Seriously.
Flying even a few knots over Vref can lead to big problems on the CRJ with a runway surface that is even slightly slippery, because the numbers are already so inflated to account for the lack of leading edge devices. This is exactly why PCL is now flying everything at Vref all the way down final instead of adding a factor. The airplane will float like crazy, and add in a slippery surface, a 7,000 foot runway becomes awfully short.
Vref + 5 with no gusts. You don't pull out the power on the 767 until ten feet or bad things happen.
You tell me. . .BUT. . .
I know that it is possible to make a speed reduction of 5-10kts without bringing the power to idle.
I don't think anyone is making the suggestion to reduce power to idle to make the adjustment from Vref+factor to Vref, rather a simple power reduction to achieve Vref as you cross the 50ft landing screen height.
Every plane lands different though. On a -200 if you aren't pulling the power back starting at 100ft you will not touch down on the markers, a -700/-900 and you will slam hard. An Airbus calls you a retard starting at 50 ft. The Md-11/10 holds ref to 50 then walks em back all the way to the autobrakes, the diesel 9 keeps the pilots busy all the way through rollout. Moral is this.... Crossing at 50ft and Vref is ideal and planned.
Josh's point is well taken for any CRJ operator. After the TVC overrun at PCL, this became a big issue at ALPA's Safety Department. Flying even a few knots over Vref can lead to big problems on the CRJ with a runway surface that is even slightly slippery, because the numbers are already so inflated to account for the lack of leading edge devices. This is exactly why PCL is now flying everything at Vref all the way down final instead of adding a factor. The airplane will float like crazy, and add in a slippery surface, a 7,000 foot runway becomes awfully short.
You may recall but I fought that one on the company forum by the horns. I only posted the AIM and FAA literature on the first 3,000 or 1/3rd of the runway. M6 on 18R, P on 36R... Bring it! I'm still rolling to the end on 27 though...... (This is talking about MEM since Kell and I are based here).
Of course, not getting into various techniques of managing airspeed in various airframes.
Crossing the 50ft screen height at Vref is what the landing data (unless otherwise noted) requires to be accurate.
Recall that my initial question, and the one I still hold in my mind, is in regards to a no crosswind/gust condition.
Vref+5 vs. Vref-5 could be debatable considering that Vref itself provides either 1.23 to even 1.3 times Vso stall margin. I'll take the difference of 1.27 x Vso for the -200, if someone has the actual that'd be great.
Vref of 142 (at MLW for a CRJ-200) comes from a Vso of 112kts (112 x 1.27 = 142.24kts). Quite the stall margin - even at Vref minus 5 (137kts).
So long as a pilot is making an effort to MAINTAIN Vref I don't see why any self-respecting professional would allow such airspeed decay prior to crossing the 50ft screen height.
