Why, you don't need a parachute to do spins.
AC 61-67 is a great resource for spins / stalls if it hasn't been mentioned before.
91.307 states
Sec. 91.307 - 91
(a) No pilot of a civil aircraft may allow a parachute that is available for emergency use to be carried in that aircraft unless it is an approved type and --
(1) If a chair type (canopy in back), it has been packed by a certificated and appropriately rated parachute rigger within the preceding 120 days; or
(2) If any other type, it has been packed by a certificated and appropriately rated parachute rigger --
(i) Within the preceding 120 days, if its canopy, shrouds, and harness are composed exclusively of nylon, rayon, or other similar synthetic fiber or materials that are substantially resistant to damage from mold, mildew, or other fungi and other rotting agents propagated in a moist environment; or
(ii) Within the preceding 60 days, if any part of the parachute is composed of silk, pongee, or other natural fiber, or materials not specified in paragraph (a)(2)(i) of this section.
(b) Except in an emergency, no pilot in command may allow, and no person may conduct, a parachute operation from an aircraft within the United States except in accordance with
part 105 of this chapter.
(c) Unless each occupant of the aircraft is wearing an approved parachute, no pilot of a civil aircraft carrying any person (other than a crewmember) may execute any intentional maneuver that exceeds --
(1) A bank of 60 degrees relative to the horizon; or
(2) A nose-up or nose-down attitude of 30 degrees relative to the horizon.
(d) Paragraph (c) of this section does not apply to --
(1) Flight tests for pilot certification or rating; or
(2) Spins and other flight maneuvers required by the regulations for any certificate or rating when given by --
(i) A certificated flight instructor; or
(ii) An airline transport pilot instructing in accordance with
§61.67 of this chapter.
(e) For the purposes of this section,
approved parachute means --
(1) A parachute manufactured under a type certificate or a technical standard order (C-23 series); or
(2) A personnel-carrying military parachute identified by an NAF, AAF, or AN drawing number, an AAF order number, or any other military designation or specification number.
<small>[Doc. No. 18334, 54 FR 34308, Aug. 18, 1989, as amended by Amdt. 91-255, 62 FR 68137, Dec. 30, 1997; Amdt. 91-268, 66 FR 23553, May 9, 2001] </small>
Thus, the private pilot area's of operations do not require spins...so yes you tech would have to wear a parachute. However how most get around this reg is to say it is just training in advance for their CFI rating that they will eventually be working towards.
