juxtapilot
Snowflake
A private pilot working on their instrument rating needs a safety pilot. The safety pilot is a current instrument rated private pilot. Can they go IMC and both log PIC?
No....The nonrated instrument pilot can only log PIC during the time in which they are VMC. Once they go IMC, the Instrument rated pilot in the airplane is the only person rated to fly in that condition making him the Pilot IN COMMAND. The nonrated instrument guy cannot log IN COMMAND time during a phase of flight he is not yet rated to fly in.
All of this should be discussed before taking off and one person shall be deemed the PIC for the whole flight if it should be operated in IMC and that person must be Instrument rated......
At least this is the way I interpret the rules....
I agree.I would say technically you could, since the instrument rated safety pilot is acting as PIC. The person under the hood is required to have him there, whether VMC or IMC if he has the hood on. I have to admit, it does sound rediculous.
Why would you have to explain it to anyone?IMHO, it wouldn't be worth the time if I needed to stop and explain and convince it to every person that looked in my log book. That's just me though.
For example, if you are over 10,000 msl, 900' below the cloud deck, and with 100 miles visibility, you are in IMC.
Explain what? That I logged hood time with a safety pilot? Is the FAA or an airline really going to have a problem with that? Read the original post again. It asks can both pilots log PIC. It doesn't say anything about logging IMC. If the left seater keeps a hood on and logs it as hood time, what is there for anyone to question?"I'm with the FAA, explain this."
"You wan a Yob, but how did you log..."
Second, IMC does not mean in the clouds. For example, if you are over 10,000 msl, 900' below the cloud deck, and with 100 miles visibility, you are in IMC.
How do you figure?
Well the cloud requirements for vfr are 1,000 below and 1,000 above.
Check the definition of IMC in the AIM:I understand that.
I still don't necessarily buy the argument that you're in IMC though.
INSTRUMENT METEOROLOGICAL CONDITIONS- Meteorological conditions expressed in terms of visibility, distance from cloud, and ceiling less than the minima specified for visual meteorological conditions.
VISUAL METEOROLOGICAL CONDITIONS- Meteorological conditions expressed in terms of visibility, distance from cloud, and ceiling equal to or better than specified minima.
Or maybe you prefer an FAR?
From FAR 170.3, "Instrument meteorological conditions (IMC) means weather conditions below the minimums prescribed for flight under Visual Flight Rules (VFR)."
"Actual" instrument conditions is the term the FAA uses for when outside conditions (as opposed to a hood) mean you can't see out an need the instruments to stay upright
I figure to use the same definitions as the FAA uses instead of making up my own.
Almost forgot about the question..A private pilot working on their instrument rating needs a safety pilot. The safety pilot is a current instrument rated private pilot. Can they go IMC and both log PIC?
This is one of those questions where we need to remember that there are times when you are not PIC or PIC qualified and yet still log PIC. And there are times when you are the actual legal PIC and yet can log nothing. This is one of those situations.I guess the answer is that if said PPL with IR is safety pilot for the PPL w/o IR, then they can take off on an IFR flight plan and when entering the soup the PPL with IR can log actual and the PPL w/o can log nothing.
OR could the PPL w/o IR log SIM IFR if they are wearing the hood and the PPL with IR log actual?
Hmm... i'm thinking probably not but you never know...
Now since the flight is being operated on an IFR flight plan and the right seater is the only one with an IR, the right seater is the only one qualified to act as PIC during that flight and is the only required crew member. However, the left seater is the sole manipulator of the controls for the entire flight. This gives us a couple of choices as far as who can log what. Legally, the right seater is entitled to log the flight as PIC and actual because he or she is the PIC as required by the regs and legally the left seater is entitled to log the flight as PIC and actual because he or she was the sole manipulator of the controls in a category and class of airplane for which he or she is rated. However, in this situation, there is no clause to allow both to log PIC. It's a one or the other type of situation. If the left seater logs the flight, the right seater legally may log nothing. If the right seater logs the flight, the left seater may log nothing.
