Kingairer
'Tiger Team' Member
"Except maintain" should not be used for lateral path guidance.Hence the “except maintain” because all I am changing is the altitude portion of the SID.
Yeah I get it, that shouldnt happen and is an FUp on them and not a poor clerance. But I get it, in that airspace I am sure you'd rather then drone around at 2000 a bit longer rather than flying into EWR traffic.Well that gets messed up even more often if I just “climb and maintain” with people staying on the initial 040 heading and not turning per the SID because they believe I have now taken them off the SID.
It depends on if traffic is above going to EWR. We leveled at 1500 just barely and was given a "climb and maintain 6000" the other day.
If we are level at 1500ft or 2000ft....just give us a "climb and maintain" and just be done with it. Enough pilots have busted the SID to where many are skiddish and a "climb via the SID" just adds another level of insecurity to the whole ordeal.
I'll say it again...the SID has gotten better, but it is more complicated than it seems at face value. The quick level off, being below the class bravo, and noise abatement procedure, getting a TA from traffic going into is also normal. Plus TEB just being TEB and everything that goes along with TEB.
No worries. Just understand that if we ask for a clarification, it’s just because we want to:Hence the “except maintain” because all I am changing is the altitude portion of
But if it were flown correctly, just saying "Radar contact, climb and maintain 6000" *should result in the airplane doing the same thing as "climb via, except maintaining 6000." The "climb via" seems an unnecessary inclusion as I have already been cleared (PDC)via the TEB1 departure (but it sounds like crews are Fin this up, so I get why you are renforcing it)Climb via is the lateral guidance. Except maintain is vertical guidance. Otherwise you’d be on vectors.
You’ll never get a climb via on the WENTZ. This is just the Teterboro 4 departure off 1 and 6.
Hes about to issue you a phone number.Maybe they should just change the Sid and get rid of the top altitude, or make it higher. Then you can issue the lower altitude if you need it.
His hair is on his face.I do not believe NovemberEcho has hair. But you just caused him to pull out his last strand because of you. LOL
If it had lower altitude restriction (which this one has none) theyd all still apply in an "except" clearance, only the top would be changed.Originally how i interpret it. Fly the SID, climb the SID, except that any altitude restrictions are now replaced with an instruction to go directly to 6000’
You can absolutely make that happen if you are determined.One of my life goals is on my last day of flying, to have ATC ask me to copy a phone number, so I can say:
“If it’s your mom’s house, we already have it”.
Honestly, the FAA’s willingness to allow the shenanigans at TEB, SMO, PWK, BFI (insert GA airport near big boy airport here) shows the priority on pushing airline tin over GA safety. For instance, an airline would never accept having to cancel IFR in MVFR and flying some awkward in between a traffic pattern and circling maneuver, and yet that’s any time the winds are out of the north at PWK. But we can’t delay the 5th RJ of the day to South Podunk out of ORD. I’ll get off my soap box the day the airlines are reregulated.Plus TEB just being TEB and everything that goes along with TEB.
I’m not a huge fan of “climb via, EXCEPT…”. I’d prefer “Climb via TO XXX”, or “Climb to XXX, Comply with restrictions”, but it is what it is. I can deal.
That's on them, friend.Well that gets messed up even more often if I just “climb and maintain” with people staying on the initial 040 heading and not turning per the SID because they believe I have now taken them off the SID.
