BEEF SUPREME
I'm happy the NTSB arrived at the assessment of heli ops so close to the final approach to 33 as an "intolerable risk."
Am surprised there hadn’t been traffic conflict alerts with this until now. Unless there has and it’s just never been reported. Even if two aircraft on their exact altitudes when they cross this point, there’s only 100’ separation at best,
That would be apparent on the helo CVR, as it should’ve kept running to impact.
Helo was probably under the right wing most of the time, until it likely suddenly bloomed out from u dear the wing at 1 second or so to impact.
My understanding is that it is only 75' and that is only if the arriving aircraft isn't below the glidepath and the heli is within the altitude constraint
The CRJ was rolled out on final approach 7 seconds before impact.
And what would be apparent on the heli? Crush damage at impact for the cabin?
There have been hundreds (probably thousands) of TAs on that approach in the last 20 years. They just get ignored normally because you assume the guy who said he would maintain visual separation is going to actually maintain visual separation.
The RJ seemed to be still be somewhat wing up, in its turn about to roll out, or rolling out.
The helo would have damage to the blade and rotor system, and tailboom. But much of the fuselage crush damage of it would be post-impact when it hit the water inverted.
I think that’s the angle of the video taken. The first video. The second video seems to show more clearly, that the CRJ is pretty much near wings level.
Is it your guess the 3 were alive then after impact? If so I wonder if there was any recognition of what happened. The CRJ crew knew 1 second before and tried to avoid it.
The explosion and G forces from impact would have killed many of them instantly, right?So would it be fair to say that the large explosion is the fuel in the left wing catching fire as it fails/disintegrates?
And what about the heli? I thought it was a body smash, meaning near instant death of those in the heli. But if only the rotors hit, then the cabin wasn’t compromised, and they were alive going down.![]()
Instantaneous load of 10G (IE gettin t-boned) is briefed to cause immediate fatal damage to the body. It’s why all the survivability in helo’s is designed around keeping the load vertical and minimizing the impact forces through crash seats or landing gear. Vertical on the Apache which is our most survivable the instant load rating is 28G before becoming fatal by comparison.
It’s very likely dependent on load that even if they had been alive post immediate impact that fatal internal bleeding was occurring. We had pretty recent crash where a helicopter come down on its side where the crew sustained no external injuries but the internal bleeding from the ruptured aorta led to it being by fatal for one of the crew.
All the years I flew at PSA I never did the circle to land at night. It was always during the day.
