killbilly
So, the best advice you've gotten here came from @USMCmech - the man knows a thing or three about flight instruction and what he said absolutely mirrors what I would tell you. ACS says you get -0 / +200 ', so if you're using the 1000' markers, they're 150 feet long. In my experience, if you do it right in a 172, no wind, aiming between 2nd-3rd stripe usually gets you into a roundout that puts the mains on the base of the markers.
This is true, but on the checkride - depending on which checkride you have and which examiner you're working with - this may not be an option - some will let you do it because a go-around is also a required task, but others have argued that because it's an emergency maneuver, a go-around is not an option.
@MikeD - on the advice about full trim....I agree with everything you said, but I do want to minimize some of the risks for students trying to practice these at busy fields where the go-around is more likely. Go around with full nose-up trim will go south REALLY quickly if they're not Johnny On The Spot with the trim wheel. Probably makes sense to force that very issue with practice and an instructor a few times so they can see just how much forward yoke/downforce is needed to counter that trim when power is applied abruptly. We find that about 2.5-3 turns of nose up trim and flaps 10 yields a good power-off glide that can be managed and then, as @USMCmech said, managing the energy with the slip helps the situation.
Not saying you're wrong at all...this is more about technique than anything else.
Don’t be afraid to go around if you know you screwed it up. It’s a hard maneuver, imo.
